Back to:
Tags:
Intel D850MV Motherboard
Can't start bios (by 17 users)
posted by frxed on Jul 06, 2006
i can't start my motherboard bios, no beep, not bios output (black screen). The power supply is ok (i tried a new one). Can it be the processor ? the memory or the mother board itself ? Thank you for your help. Frederic
Comment by frxed, posted on Jul 11, 2006
Unfortunately, no one of the suggestions hase solved the problem. Memories are good as well as the processor and the graphic card. I have not seen the reset button under the battery. I am now looking for a motherboad and hope it will fix the problem. Anyway, thank you for your help. Frederic
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
16 Other Users Have The Same Problem
Comment by mugglesquop, posted on Sep 19, 2008
i have the same problem, all brand new parts :(
Comment by Guest, posted on Aug 31, 2008
I have the same problem. And, in addition, several transistors near the main 24-pin power connector on motherboard become very hot, when i turn on the power button (without memory modules and video card - I have the same effect). The power unit is working; this configuratian was working for two years; i think this is breaking in some motheboard unit.
Comment by tousher84, posted on Aug 12, 2008
When I start my PC then Asus P4SE motherboard does not show BIOS.
1st time I am swap 2RAM(128MB,256MB), but show same problem.
2nd time we remove motherboard battery, also show same this problem.
Please help me.
Comment by neo1172, posted on May 11, 2008
I have one 8LD533 F2 motherboard, when I Power on the PC from UPS a small light glows up on motherboard and when I press power button on CPU it goes off; neither fan nor any other activity is there. what's the problem?
Comment by Ravensville, posted on May 09, 2008
I torn on the pc.everything powers up ok,,all lights + all fans are operating correctly, and all i get is a black screen. there is no access 2 the bios........ I have tried switching the jumpers, nothing. I even bought + replaced my graphics card. still nothing...... any suggestions would be much appreciated.....thanx ...
Best Solution
posted on Jul 07, 2006
Helpful (85)
bmwrider
Rank:Wiz Wiz
Rating: 85%, 1767 votes
Often no beeps from the motherboad can mean faulty memory. If you are running two sticks of RAM remove one and see what happens. If it still doesn't boot then swap the sticks over and run the other one.
Next check your video card, then your CPU then as a last resort the motherboard.
You can do all this by swapping parts with a friend's computer. As lomg as he has the smae CPU.
Personally I'd put my money on the memory or Video card. If the videp card is a AGP it's OK to try it out with a PCI just to see if it works. If the video is onboard check your manual to find out how to disable it. It's usually a jumper which is great but if it's via the bios just put the card in anyway and see if the system finds it by itself.
BMW
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on can't start bios:
I don't want to Accept this solution
Solution #2
posted on Jul 06, 2006
Helpful (85)
dovi
Rank:Guru Guru
Rating: 88%, 2269 votes
Did you make any changes before it occur (new hardware, new or updated software)?
Thank You!
Solution #3
posted on May 19, 2007
Helpful (85)
kevinbladex
Rank:Apprentice Apprentice
Rating: 78%, 2 votes
Heyy.. i have the same problem with my computer... Its a Biostar M7VIZ Ver 1.3...
My problem is that.. when i boot my computer.. nothing show's up on the monitor. As soon as i boot it.. it just puts on the Red LED light and the hard drives powers up and the cd Rom powers up also... I'm able to open and close the CD Rom Drive... But the Monitor won't start!.. its not a Monitor problem.. because i'm using it right now with another computer. i have two sticks of Memory and this is a 1.66Ghz Windows XP Home Edition...
i would really appreciate someone reponding to this and really help mee!!...
THANKZ IN ADVANCED!!
Thank You!
Solution #4
Thanks for Trying (70)
The Fizz
Rank:Master Master
Rating: 84%, 126 votes
If its not a brand new motherboard, id un-plug it, pull out the small battery and switch the reset jumper to reset it. If that doesnt work, check to make sure its not infact a graphics card problem.
Thank You!
Solution #5
posted on Jul 31, 2007
Guest
Rating: 0%, 0 votes
cpu fault
Thank You!
Solution #6
posted on Sep 03, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Like bmwrider said: remove/replace your ram, try single rank (chips on one side of the stick) and double rank ram (chips on both sides of the stick) and see if that works.
Mobo's are funny things so if this works it doesn't mean your ram is faulty and it's very well possible your computer will boot up when you put your old ram back in some other time.
Thank You!
Solution #7
posted on Aug 04, 2008
Not Rated (0)
howardshum
Rating: 0%, 0 votes
Use a stable and new transformer
Thank You!
Solution #8
posted on May 05, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
change the motherboard..... is a electrolitic condenser problem... sorry...
Thank You!
Solution #9
posted on Feb 11, 2008
Not Rated (0)
Satyapal
Rating: 0%, 0 votes
This is sure due to bad bios / cmos, try to reprogram the flash ic with appropriate bios file yourself ( if u have programmer) otherwise bring it to service person who has the programmer, i think the problem should be gone.
Satyapal
satyapalmh@gmail.com
Thank You!
Solution #10
posted on Feb 04, 2008
Not Rated (0)
drgunno
Rating: 0%, 0 votes
I can add some more info but no solution. I suspect the bios as the culprit. I have 3 computers with same fault ocuring during XP pro install. All occured during the IDE driver install; yet they all had SATA/floppy support. I have managed to monitor the memory being accessed and read on the board yet no further activity on the board. I can not get access to the bios to change anything & cmos reset achieves nothing. I have stress tested all the individual components in other machines and they are fine. Given the mobo has activity on it I have put them aside for a rainy month when I can get in at chip level....oneday. All I can sugest is if the fault occured during an XP pro install where it hung up mid way(usually around IDE drivers) then do not just turf stuff in the bin. The mobo is the tricky part to this problem. Yet there is a common link. I have a Saphire SLI board and an Abit NF7S board that also have this problem. All occured during XP pro SP2 install at aproximately the IDE driver part. The only common links are XP pro SP2 and silicon 3112 sata chip. Also all boards fail to switch off. You have to turn off pwr at the mains to disconect. This may not help with the mobo but should save you getting ripped off on PSU, MEM,VGA trades conned into buy ripoff traders.
Thank You!
Solution #11
posted on Nov 11, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Reset your Bios by pulling the jumper on the motherboard and replacing it. This will re-set everything up till the point it stopped working. other computers you can just pull the battery and wait a few sec's before putting it back in
Thank You!
Solution #12
posted on Oct 26, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
reset bios setting all to default
reboot pc
Thank You!
Solution #13
posted on Aug 13, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I had exactly the same thing happen, i came to the conclusion after testing cpu ram videocard that it is a factory inherent fault with the motherboard something to do with the 8 pin 12v connector not throuputting power, i just got my 2nd one in the mail (the pc shop tested it too n agree with me) and much to my dismay it has the same fault :( soultion send it back n buy a different brand
Thank You!
Solution #14
posted on Jun 28, 2007
Not Rated (0)
petrotech
Rating: 0%, 0 votes
one of the LEDs that plug in to the MB is shorted bringing down the power supply. I found out the hard way.
Thank You!
Solution #15
posted on Jun 25, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I have this problem and every time I remove the graphics card and wait 3 seconds and then plug it back in and then unplug the power from the unit, plug it back in, the unit will boot back up. This goes for both PCI-Express and a simple 32mb PCI card, which means its not MOBO specific for the slot not working, and its not specific to the card, so something else on the MOBO? I have been so frustrated with this problem since I built the system but now its getting more frequent.
Thank You!
Solution #16
posted on Jun 18, 2007
Not Rated (0)
scotty23
Rating: 0%, 0 votes
i have one of these boards and had the same problem if you will refer to the manual it will tell you how to reset the board
Thank You!
Solution #17
posted on Jun 17, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
try replacing the motherboard battery
Thank You!
Solution #18
posted on Apr 25, 2007
Not Rated (0)
bapplay
Rank:Master Master
Rating: 81%, 38 votes
For a new board you will need to set the jumper near the cmos battery.....these normally are switched off to save battery life if the product is on the shelf for a long while.....check the manully that comes with the board to ensure that you are changing the right jumper..
Thank You!
Can you Help with these Motherboards problems?
Motherboards
I have a MARS Foxconn motherboard ,i have a problem with...
where to find ZX-I945LM4 (zx technology) motherboard...
boa tarde eu preciso saber qual drive eu procuro para a...
I'm a Dummy! I totally read the pin #'s on the M.B....
Thank you for attempting to find a solution to my problem....
16 Other Users Have The Same Problem - Continued
Comment by wens1988, posted on May 01, 2008
can't start bios problem
Comment by rvaag, posted on Mar 30, 2008
pc chips p17g pci device
Comment by Guest, posted on Mar 29, 2008
the screen is blockout, I've ilready ckeck the memoty processorand video card. it means my motherboard has the problem
Comment by Guest, posted on Jan 27, 2008
samething no bois boot but get coninuous beeps thanks bo colo sprgs
Comment by seanoutlaw, posted on Jan 21, 2008
hello everyone..i have an aopen mx4gvr,an presently having the same problem.it all started when my power supply died,got it replaced...then strangely after that the board never booted up like how it normally used to.when the ac power cord is pluged in,the board lights up,this meaning that i do not have to press the power button,as mains is connected,the fan on the processor and power supply are on.i could also observe three lights staying on constantly.the internal(on the motherboard) boot led and the stby led(standby),and on the outside of the case the power light stay on.i first tried clearing the cmos using the jumper meathod which didn't had no impact,then i thought it was a memory issue,no beeps or sounds are heard by the way.i got a friend who has the same pc as i do,tried his memory and same thing.i once again got a video/graphic ADD card to try to solve the problem hoping that it was my onboard video or graphics card which went bad,once again same problem...i tried disconnecting everything form the board,the cd drive,hard drive,etc..same problem...i then thought that somehow the board went dead.then again i was told when the board is dead,no power goes into it..so please i am asking anybody out there who has had this expirence to please help me out.......or for that matter any other information as to a work around will be greately acknoweledged..thank you...sean....please contact me at seanoutlaw@hotmail.com if any info can be given.
Comment by gabygybonu, posted on Jan 06, 2008
Same problem with me. I can't start my motherboard bios, no beep, not bios output (black screen). All components are OK. Does anybody can help me pls?
Comment by Guest, posted on Dec 27, 2007
I had to flash the bios with the newest version. Floppy hung. Had to boot with win98 boot disc with cd rom support. Then I flashed the bios from the cd. All is well with this particular issue. Still have mic issues though.
Comment by Guest, posted on Dec 20, 2007
Comment by Guest, posted on Dec 17, 2007
i have found a pdf. on your board and there is a three pin jumper next to the onbord speaker you put a jumper from the pin furthest away from the battery to the center pin then plug in your power cord and see if it will post
this is the config mode of your bios when you are done setting ur bios shut down ur pc and move the jumper over one pin and restart if this doesn't
help then you need to ask intel for a new bios chip or some recovery ideas!!
from brightg@excite.com
Comment by MEGAPODIDO, posted on Dec 03, 2007
I BOUGH A MATCH SPEED MATRIX P4M800 MOTHERBOARD 2 YEAR AGO BUT ONLY WORK AS 10 OR 12 DAYS,THEN NO BOOT DESPITE I HAVE 1200 MB_RAM AND INTEL PRESCOT 3,2 PROCESOR. I DO NOT IF NEED TO SET INTO DRIVE ANY BOOTABLE DISC EVERY TIME.
HELP ME PLEASE
Comment by rush_will, posted on Nov 26, 2007
i'm having huge problem with motherboard. video never works. i really believe no video is onboard. but i've tried a bunch of memory. i'm going to buy certified memory that works but i've tried agp port video cards like 6 or 7 times. i keep getting 8x cards, but manual says 4x or 1x at the most. does that really matter? i was hoping it didn't, but i keep getting black screen on monitor when i boot up. i also tried a video card in the pci slot to no luck. i'm wondering if anyone has any new info that can help me. i have an intel P4 3.4ghz chip with a chiefmax 550w powersupply. seagate barracuda harddrive. besides memory does anyone know if what i mentioned would make the computer not boot up?
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
