Question about Nikon Cameras
Nikon d80 camera with white back drop and studio lights...backdrop looks blue...not pure white
  • 489 Answers
HI
You need to change your white balance I think. I found the settings on page 70 of the online manual.
www nikonusa com/pdf/manuals/noprint/D80_noprint pdf
Good luck from Darntoothysam com
Thomas
Posted on Oct 21, 2008
After taking pictures with bright colors, image in the viewer blink black/white over brightly lit objects...Help, it's making me crazy!
You're seeing blown-out highlights. These are the portions of your picture that have been so overexposed that they've gone pure white, losing all detail. This is generally considered a bad thing so the camera is warning you about it. But the camera doesn't know what you're taking a picture of, things like the sun reflecting off polished chrome should go pure white, so it's just a warning.
Usually the proper fix is to reduce exposure, bringing back the lost details. This risks losing details in the shadows as they go pure black, but that's generally considered not as bad. After all, we don't expect to see things in the dark.
That was the long answer. The short answer is to press up/down on the multiselector to cycle through the different views of your picture.
May 18, 2011 | Nikon D80 Digital Camera with 18-55mm Lens
Need a Nikon D80 Service Manual
http://www.pdfoo.com/result-nikon-d80-repair-manual.html is one website. Doing a Google or Bing I found numerous sites that have these. Maybe contacting Nikon direct will be a better choice for you: 1-800-645-6689
Jun 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
Black patches start blinking on photos played back
You're seeing blown-out highlights. These are the portions of your pictures which have been overexposed so much that all detail has been lost. If printed, they will show up as pure white, without a hint of shading.
The "correct" fix is to reduce the exposure by using exposure compensation to bring back the details. Blocked-up shadows (the same thing at the other end of the brightness scale, where dark objects go pure black) is generally considered less harmful to the final image.
That was the long answer. The short answer is: Press up/down on the multiselector to cycle through the different views available.
May 28, 2010 | Nikon D80 Digital Camera with 18-135mm...
I want to know what setting to put my Nikon D80 on
keep the camera in manual mode and increase ISO more than 800 and shutter speed should be low , for black &white picture go setup in pencil mark & go to black&white option
Sep 06, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 red and green streaking
check on the shutter speed and also the Aperture priority..
Jul 27, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
Hightlight message on Nikon D80
Highlight is just the info mode, there are several info modes including Basic file info, Shooting Info and RGB histogram, just press the round controller in the up or down direction to change between them in playback mode. Highlight will flash black anywhere there is pure white in an image.
Try resetting the camera by pressing the 2 buttons with green dots (on top of the camera near the shutter release) holding them for a few seconds.
Mar 08, 2009 | Cameras
Yellow/green tint indoor photo using auto portrait mode
Hi - You can download the Nikon D80 Guide to Digital Photography manual by clicking the link underlined in blue below:
Nikon d80
Firstly see page 58:
Try setting the white balance to fluorescent an compare. Also you could set your own white balance preset by shooting a white card as per page 59. Lastly you can play with the "tone adjustment" on page 80.
Let us know how you get on!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 11, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 camera
While in playback mode press up or down on the 4-way controller to toggle between highlights, shooting info, custom settings, histogram, or none.
May 18, 2008 | Nikon D80 Digital Camera with 18-135mm...
Losing green / torquoise tones
I'm betting you just have to adjust the white balance properly.  The D80 allows you to set the white balance against a grey target.  There are two ways of doing this.  First, you can put a reference grey target right on the painting, set it, and then remove the target while using the white balance you just set.  Alternatively, you can cover the lens with a diffuser of some sort, like a piece of white paper and hold the camera right where the painting will be, but pointed back towards where the light is coming from so that the diffuser is being bathed in that same light.
In case you don't know how to set the preset white balance, I suggest checking the manual.  I use a D70s, so the procedure may be very slightly different on the two cameras, but the idea is the same.  The key is that if you do this, you are pretty much guaranteed to get proper colors every time - not just now, but anywhere.  I do this often.  All that is required is a perfectly neutral patch (white to black, but with no color at all) that is being lit with the same light as you are trying to photograph in.  It takes about 5 seconds and presto - perfect white balance.  Note that this is for making pictures that look EXACTLY LIKE THEY WOULD IN PURE WHITE LIGHT.  So, it isn't for capturing proper sunsets, etc.
Good luck.
Jan 17, 2008 | Nikon D80 Digital Camera with 18-135mm...
Consistent under exposure
Under exposed should be minus not plus number.
Lucky you didn't buy Canon 5D or 1D- they have focus and exposure problems.
Hope you are not using the pop flash that is on the camera. If you are, then turn off the Red Eyes Modes.
Set camera to manual mode and lower the F number(open up to half or one stop).
What studio lights are you using? Increased the light output of studio by those number and shoot like you normally do.
atdlee@netzero.com
Dec 11, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Cameras Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
