Question about Saeco Odea Go
Odea go Mirran Help I just got my odea go I filled the water, added the beans. I powered it up and it made a brief sound. The red warning light is on all of the time to the L of the spout. When I push the steam button on the R, the green indicator begins to flash to the L of the spout. Wont feed water or steam, or brew. Please email me at tumorablation @gmail.com
  • matt666666 Jan 18, 2009
    All the parts seem to be installed in the right place and the alarm light never goes out (solid on), and the water never comes out.
  • ton079 Mar 25, 2009
    In my machine beans were added, water was filled up, the "press"-module was cleaned by having it under streaming clean water.
    Powered off and on and when pressing the button for a cup of coffee, it makes a short sound as if it will crush the beans, but stopped with red light on.
    Machine is approx. 7 months old.
  • 515 Answers
Make sure all part is on place, take out the watertank and put it back again, make sure the brewing unit is fit in place.
After all part is on place, put a container under the steampipe and open the steam knob to make a cup of water, when the water comes in a steady flow, then you can close the steam knob again.
Hope this will help you.
Best regards
/Mirran
Posted on Oct 26, 2008
Barista supremo thinks it doesn't have coffee beans
http://www.espressotec.com/media/downloads/57/SA1260_Odea_Giro_plus_manual.pdf The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
Red light on, not blinking
make sure your steam button is completely turned off
Jan 14, 2012 | Saeco Odea Giro Plus Coffee Maker
I have descaled my Saeco Odea and the coffee beans light and the descaling light keep on flashing from one to the other
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
Dec 06, 2009 | Saeco Odea Go
Odea go dumps shot
Try this remove the brew unit and clean the screen, the red light is saying that it cannot push water through.
Jul 04, 2009 | Saeco Odea Go
Saeco Odea Giro highlights the "!" light and wont spurt water.
Try this open the steam knob for about 5 seconds then turn it to the rest(off) position, make sure that it is in the off position.
Jun 12, 2009 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Saeco Easy red light stays on
Make sure the magnet in the water tank flow up when you fill the water tank. Look at the dregsbox and make sure you have a little pin that goes into the machine.
Best regards
/Mirran
Oct 19, 2008 | Saeco Easy Espresso Machine
Saeca odea giro
Sorry for the delay, i´m on sick-list and have limited access to computer.
To prime the machine you have to put a container under the steam pipe, open the steamknob on the top of the machine. Let the pump go to there is a steady flow of water then you can close the steam knob again.
I´m not sure if you done this already.
Let me know if i can help you more.
Best regards
/Mirran
Oct 09, 2008 | Saeco Odea Go
Red alarm light permanently on!
Hi.
First turnthe machine on.
Then take out everything watertank, dreg draw and brewingunit and have the door opened to the brewing area.
have them out for about 1 minute and then put it back together again.
if this dosent help please check if the machine respond to removing the dregdraw, beanlid.
It will do it by making the constant red ligth flash instead.
if they respond make sure that the watertank is filled to max.
if that is the case it is the watertank sensor that is broken.
May 26, 2008 | Saeco Odea Giro Espresso Maker -...
Saeco Odea Go Logo
420 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
