Question about Toshiba MD20FN3 20 in. TV/DVD Combo
My remote control does not work
The original remote control that comes with the television stopped working. Originally I thought new batteries would be a solution, but that didnt work. I figure the remote was broken, so I purchased a brand new remote (not universal) and new remote still does not work. Is there something wrong with the TV, is it not recieving the signals from the remote? please help...thanks for your time.
  • 1 more comment
  • dave670 Apr 26, 2008
    replaced the batteries and tried a universal remote , still no signal
  • dlewis114 Jan 29, 2009
    Hi I am having the same problem. Before I found this website I thought it might be the IR sensor. Do you know what the operating voltage and frequency is of the sensor? If I'm reading it correctly it is 37kHz.
    I would apreceate any info you could offer on the subject.
    Thanks
    Danilel
  • Anonymous Mar 18, 2014
    my remote for my Hikona tvd5001 has been broken beyond repair. I need a new remote to be able to control my programs etc
    President:
  • 3,130 Answers
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Posted on Jul 06, 2006
SOURCE:
There is no TV button to press on rc-017 remote, setup instructions say press on tv button till led lights up.
If you mean the Coby RC-017 remote, it is not a universal remote that can be set to control any TV or other device. This remote will only work with the TV for which it was originally programmed. I believe it should work for a TF-TV1511, if both the remote transmitter and television IR sensor are working. Assuming you have the correct TV, try just pressing the power button.
I hope this helps.
(I suspect you found the directions for the Coby Universal Replacement Remote which controls several devices.)
Dec 01, 2015 | Televison & Video
Why has my JMB TV stopped responding to the remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Aug 18, 2014 | Televison & Video
RCA 244889 stopped working
hi,have an rca remote control model number 244889,it no longer works, I've treid repalcing hte batteries and nothing will work,the light does not come on,not sure where to buy one like the original,as it will be the only one that will work the television.
Aug 05, 2013 | RCA 244889 Remote Control
I cannot control the TV with remote control. Originally, I thought the remote control did not work. I ordered a new control, and still it did not work
To ensure that your remote is working correctly (infrared) take your cell phone, switch on the camera mode, now point the remote towards the camera lens and press the remote button, you shall see a red light come up on your cell phone screen, if this means your remote is fine the problem is with the receiver on the television.
Feb 27, 2011 | Televison & Video
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Dec 15, 2009 | RCA Universal Remote Control
My remote control stopped working ,new batteries did not help...even tried a new one, still didn't work....any thoughts...
Get auniversal remote or a new original. If your handy you could take apart the bad one and look for bad solder contacts (or something spilled in it)
Sep 21, 2009 | Philips Magnavox 27MS343S 27" TV
All of a sudden my TV remotes do not work properly
Since you said that the remote that originally came with the television does not work either, it's most likely a problem with the IR sensor in your television.
To make sure that something more important with the television did not fail, the next time this occurs, walk up to the television and attempt to manually change the options using its controls.
Nov 19, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Remote Control not working for MW24FM3 Toshiba
I have the same problem with my unit. I use the original remote and my Tivo remote. Both stopped working at the same time. Ocassionally they will work for awhile then stop. They always both work or both don't. Therefore it must be the TV; likely the sensor or something connected to it. Sorry I don't have a solution. Guess I need to take it to the shop.
May 07, 2008 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
Toshiba MD20FN3 20 in. TV/DVD Combo Logo
331 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
