Question about NEC Computers & Internet
Nec monitor LCD1560V
My screen display is too wide. If I use controls on monitor to move screen to right or left, the whole screen moves & it just leaves a blank on right or
left. I need to shrink R & L simultaniouly.Any ideas?
Bob
  • armjoa Oct 21, 2008
    Still have same problem. Tool bar, top & bottom are good. Also, when I open mail, mail opens to correct size for window. It's just the home page contents & anything I click on in the home page are too big to fit window. I have to use right & left arrows on bottom to read.
    President:
  • 2,712 Answers
Try changing the resolution of the screen. Right click on an empty area of the desktop and select properties. Now choose the Settings tab and try adjusting the slider for resolution and click on APPLY. The screen will go blank for a few seconds and will show up in the new resolution. If you find it satisfactory, click OK to keep it, or click NO to go back and try a different resolution.
You can also go into Control Panel and check the monitor properties from there.
Hope that helps!
Posted on Oct 21, 2008
  • Swilin Sampson
    Swilin Sampson Oct 21, 2008
    Try this...when on the page, hold down the CTRL and press the minus sign (-) till yo get the correct size you want. That should do the trick.
    PS, I would appreciate if you could re-rate the solution, as a "Thanks for Trying" is a negative rating. Thanks in advance,
    IrishDruid.
DISPLAYING ON SCREEN THAT VIDEO INPUT OUT OF RANGE
Right click on the back ground of the computer desktop. If windows XP click properties, if vista click personalise. Now look for settings and move the resolution slider to 1024 X 768. This is the native resolution for this monitor.
If you still have the HZ error, click on advance look for the monitor tab, and make sure it is set to 60Hz
Mar 02, 2012 | NEC MultiSync LCD1525V (White) 15.1" LCD...
Computer screen too wide
You just need to change your screen resolution to fit the monitor. Right click an empty spot on the desktop and left click on Properties. This will bring up your Display Properties. Click the Settings Tab at the top right and you will see a slider bar on the middle left. Move the slider bar to the right or left one bit at a time and hit the "Apply" button. The screen resolution will change and if it does not look right, then cancel the change and go to the nest resolution setting. Repeat this process till you get a resolution that works well with your monitor. Cheers!
Oct 28, 2010 | Microsoft Windows XP Professional
Settings have been changed.
Change the resolution in your PC control panel/display settings tab.
Jun 08, 2010 | Acer 22" X223w LCD Monitor
How can I adjust the screen wobble on a alienware aurora m9700 laptop.
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
May 29, 2010 | Alienware PC Systems Alienware Aurora High...
The text is too tall and not wide enough. How do i adjust the monitor?
If you are using Xp right click on a blank spot on the desk top select properties,in the display properties you will see settings.There is a option to adjust the screen size,move the bar to the left will increase the size.Under vVsta you will right click on a blank spot on your desktop select personalize,select display settings there you can adjust the bar to the left to adjust your display.Remember to apply the changes before you exit.
Good luck
Sep 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
How do I reduce the size of the picture on my PC monitor
try going to page on the top right corner click on that and then click on zoom and make sure the zoom is set on 100%
May 18, 2009 | Sova DSV32P112 32 in. LCD Television
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Monitor display is totally moved to the left.
Start >> Control Panel >> Display >> Settings >> Advanced >> Intel(R) Extreme Graphics 2 >> Graphics Properties >> Hot Keys >> Check mark on Enable Hot Keys >> APPLY.
Now press ALT + CTRL + up (ARROW).
Make sure after doing this uncheck on Enable Hot Keys.
Deepak
freakid@rediffmail.com
Feb 18, 2007 | HP Compaq S9500 19" CRT Monitor
Computers & Internet Logo
349 people viewed this question
Top NEC Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
