Question about Acer Computers & Internet
How do you instal a memory chip into a acer 5315
  • 749 Answers
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size.
Posted on Oct 21, 2008
Aspire 5315 the second memory slot doesn't work
1. For sore test this slot as single with another memory chip.
2. If doesn't work don't use it more otherwise PC will not work stability. Use only one slot with higher Gb memory.
Oct 04, 2013 | Acer Aspire Computers & Internet
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
How do i put my camera memory card in my laptop? i have the acer aspire 5315 and a 4gb SDHC memory card
Hi
if you look on one of the sides there should be a slot about the same size as your memory card
slot it in and hopefully windows will reconise it
if not leave the card in and restart the laptop
hopefully windows will install and look for a driver for it as well
if not go to www.acer.com go to support/downloads making sure that you get the correct driver for
your make model and operating system then scroll down and look for the driver download it and install it
hope this works for you good luck
Feb 13, 2011 | Acer Aspire 5315 Notebook
Does the acer aspire 5315 2077 require a certain type of memory?
Go to www.crucial.com and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: Yes.
Jan 14, 2010 | Acer Aspire 5315 Notebook
About graphic card of ace aspire 5335 and rendering
As this chip has no dedicated video memory it will be dependent on how much RAM you have installed in your notebook. Maximum amount it can share from system memory is 384MB. It will probably be capable of rendering the scene but depending on the complexity of your scene it could take a while.
For more info on your integrated graphics card which is an Intel Graphics Media Accelerator 4500MHD visit http://www.notebookcheck.net/Intel-Graphics-Media-Accelerator-4500MHD-GMA-X4500MHD.9883.0.html
Sep 27, 2009 | Acer Computers & Internet
How do I install memory in Acer Aspire 5315-2290? It has 2 512MB in it. I have 1 2G chip. Do I remove both chips? Do I need 2 chips to put back in?
One OR two chips will work, mix or match; however,
Don't mix different "speed" chips.
If all three chips are the same speed/type, PC2-5300? Then you can use the 2GB AND the 512MB together (1.5GB total).
Hope this helps!
Sep 12, 2009 | Acer Aspire 5315 Notebook
Memory up grade acer5315
unscrew the panel with a little symbol that looks like a chip then inset the modules with quite some force.Just dont break them cus they are expensive!
Jun 20, 2009 | Acer Aspire 5315 Notebook
Installing Acer 5315 series memory
Laptops use a different type of RAM unlike a tower computer, the RAM is like little square pieces. Unscrew the cover, lift the old RAM out and replace with the new. Its located on the back or underside of the computer.
Jan 09, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
