Question about Magma DM10-016LP Grill
Flames get out of control when grilling meat w/ fat and when windy the flame goes out.
I have the portable size Magma grill. Little round unit 16", attached to gas outlet. It doesn't seem to have anywhere for grease to drain out, so the grease builds inside and then when cooking chicken w/ skin on, or steaks, a grease fire gets going that's out of control. I don't seem to be able to even cook these things on low heat, it still generates a fire, or is so low the meat never cooks. Only thing that I can cook is boneless, skinless chicken on med low w/o fire flare up. Is there something I'm not doing right? The other problem is that I have the unit on a covered deck, so it doesn't get direct wind, but even so, when it's windy outside, it causes the flame to go out REPEATEDLY. The cover has holes in it that are always open, so the wind just knocks out the flame, and you can't keep it going whenever it's windy outside. Help! I paid $500 for this grill and can hardly use it.
  • 906 Answers
Good day,
hope this link below will solve your problem.
grilling
Posted on Aug 05, 2010
With the lid closed the grill gets up to 700 degrees. How can I regulate it down?
The control knob on the right side of the grill, below ignitor button, is what you use to control the flame height, as well as the temperature. Opening the valve raises the flame in infinite amounts. Lowering the flame, after the grill has preheated with the lid closed, will give you better control over what you're grilling.
To be quite honest, I wasn't familiar with this grill. So, I did a little research. It's gotten rave reviews from the RV crowd and really looks like (once you get the hang of it) a great grilling experience.
Hope this helped you and Happy Grilling.
Jun 28, 2011 | Camco Olympian 5500 Stainless Steel...
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
HELLO. THIS IS MY FIRST TIME GRILLING ON MY OWN. MY QUESTION IS BY THIS GRILL NOT HAVING A LID WHAT IS THE BEST WAY TO COOK W/O HAVING TOO MUCH SMOKE. B/C I SATY IN AN APARTMENT COMPLEX IM CONCERNED ABOUT...
The best way to cook on a BQ and have min smoke is to put tin foil on the grill with only a couple holes punched it for fat to drain, and don't let flames flair up, use water botttle near by to squirt coals if flames appear and spray some to put out flame. What causes smoke is the fat and juices from the meats hitting flames, this method cuts 90 percent of that.
May 29, 2011 | Marsh Allan 86851 Grill
How to char-broil burgers
You want to know how to char broil hamburgers right? Here is what you do! Start your BBQ 5 to 10 minutes before you put your burgers on (for gas BBQ) and let the metal racks heat up. Keep the top closed to let the heat go through the unit.
If your using a charcoal bbq wait until your coils are white hot and the racks are as hot as you can get them.
Don't buy the hamburger meat that has the smaller amount of fat in it. Get the stuff that has 15 to 20% fat in it. The juice in the fat will help cook the meat and taste better in a burger.
Put your rack on the lowest place as close to your fire/coals as possible.
When the bbq is hot Take your patties and plut them on the rack. If its hot enough you should hear a sizzle sound. DO NOT TURN THE MEAT. Let it sit on the grill and every few minutes take your spatula and press the meat flat on the grill to release more juices and get more attention from the flame or coals. This is what makes the black grill lines on the meat.
You only flip a grilled burger one time after putting it on the bbq. It should cook at least ten minutes or more on one side. If you turn the meat and there are no marks on it then you didn't wait long enough.
Sep 29, 2010 | Computers & Internet
I used my Polder meat thermometer in my gas grill. The fat off the meat cause flames to touch the probe. When I looked at the read-out it said 406 degrees F and then HI degrees F. Now it just reads HI...
It is possible that the therrmometer has over shot the limit set on it .It can be spoiled because the hat was in direct contact with the probe and has resulted in the failure of the unit.
Aug 27, 2010 | Microwave Ovens
Need Manual for Sikes 3 ft Cooker
no manual needed, to much preassure means the preassure regulator is shot(the round thing on the supply line). not enough flame is usually a corroded burner
Jun 17, 2009 | Sikes Cookers CK300 Grill
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Gray meat
Sounds like the Venturi tube needs adjustment. Look underneath and fully open up the tube so the maximum amount of air gets in. As for the meat being gray, make sure that before you put the meat on, the grill has been pre-heated (with lid closed) until the temperature is pegged, and also always brush the meat with cooking oil to help insure browning. If you marinade meat, let the marinade drain off and dry meat with a paper towel.
Nov 21, 2007 | Weber Genesis Silver B Grill
Magma DM10-016LP Grill Logo
238 people viewed this question
Top Magma Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Magma Grilling Expert? Answer questions, earn points and help others
