Question about Philips Magnavox MWR10D6 DVD Recorder
Connecting the dvd player and the vcr to the tv
Which cords go where
  • 374 Answers
On the DVD player you hook the red/white and yellow cords from the DVD to one of the inputs on the back of the TV colored the same. Provided you have another RCA jack input on the tv you can connect this the same way. If not and you have a cable connection or satellite just run the coax into the input on the VCR and run a coax off the output on the VCR and run the other end into the TV. I hope this is of assistance to you.
Posted on Oct 21, 2008
I have a 1994 zennith TV/VCR COMBO I am trying to connect a dvd player to. I have one yellow video cord and one double stranded audio red/white cord. I can not get a picture. Vcr player does still work.
Connect yellow from DVD to TV. Connect white and red cables from DVD to TV. Yellow to yellow, white to white etc. Then select on the TV using the remote, the proper input (where the DVD is connected) Press PLAY on the DVD player.
Aug 19, 2010 | Zenith Televison & Video
Coaxial cord won't fit on VCR/DVD
Are you sure that the port that is unthreaded is actually coaxial. I've never seen an unthreaded coaxial port, just unthreaded push on connectors.
What color do you see on the center ring on the connection of the vcr?
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Hooking my DVD player up to my HD converter
connect as follows,,,
watch DVD as before, when VCR is off, the converter will show up on the TV
Feb 19, 2009 | Televison & Video
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
What kind of cords do you need to hook-up to a tv??
Hi and welcome to FixYa,
Offhand, the A/V cable would be readily available from most electronics supply store, Audio/Video/TV stores, MP3 and even computer shops/stores. The cable would be as shown below:
Alternately, you can connect the RF OUT of a VCR to this RF/ANT/Cable IN of the TV, set the TV to Channel 3. An RG59 patch cable would do the job. Should you want to connect a DVD, connect the Video/Audio OUTPUT of the DVD to the Video/Audio INPUT of the VCR. Incidentally, the regular cable/ant should be connected to the RF IN of the VCR.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 13, 2008 | Philips DVP3345V/17 DVD Player/VCR
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
Can't get my DVD player to work...
Your GE TV most likely doesn't have anything but a antenna input on it? If that the case to connect a DVD player you must purchase a RF modulator to convert the video and audio output of a DVD player to a channel 3 or 4 output. Here is a link for one at Radio Shack.
Nov 30, 2007 | GE 27GT271 TV
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Philips Magnavox MWR10D6 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
