Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid superba icemaker leaking/freezing in freezer section
Kitchenaid superba icemaker makes ice, freezer is cold enough but water is leaking and freezing in big drips down front of freezer bins. We installed new filter, took icemaker unit out and thawed and cleaned, reinstalled, but problem is before the ice leaves the main unit.
  • 8 more comments
  • Camarillomom Nov 05, 2008
    I am having the same problem.
  • frif Dec 13, 2008
    We just bought a new Kitchenaid side by side (different model) and we are having the same problem with the ice maker dripping inside of the freezer.
  • Anonymous Mar 26, 2009
    kitchenaid ksrg25fksso4,started leaking water down the inside, i removed the icemaker cleaned it and now it will not work, how do i trouble shoot the unit to find the problem?
  • ganders Apr 08, 2009
    Model KSRS25FGWH01-water is dripping inside the freezer from the ice maker. Water also drips out the ice chute on the front of the freezer section onto the floor.
  • Anonymous May 03, 2009
    same here. everything sucks these days
  • Rebee May 04, 2009
    Had repairs made to only the ice maker every year for the 5 year warranty. Ice maker has continued to have problems. Noticed frost on auto dispenser and ice was clumping and not dispensing through door. The clumping was caused by water dripping into ice container from the ice making mechanism. Over a couple weeks time, the water dripping worsened and the ice in the container sticks together to the point where the arm that pushes cubes through the dispenser can't turn. Also, the ice maker has also frozen with a load of ice half way through a turn so it has stopped working. KitchenAid should issue a recall on this model's ice maker - it's the right thing to do!
  • purplie3
    purplie3 Sep 10, 2012
    Same problem here??? where's the solution on here??
  • purplie3
    I'm having the same problem, where's the answer on here??
  • Anonymous Mar 25, 2014
    water freezes up down water tray at the back and runs down ice been make all ice one big chunck
  • Anonymous Mar 28, 2014
    It was installed in 2001 - It does not makes ice - the frezzer does not really freeze anything; the refrigerator part is not really cold
  • 57 Answers
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Posted on Nov 09, 2008
Thank you, I am going to go check right now
ICEMAKER HAS NO WATER IN IT AND ICE STRIPPER NOT MOVING BUT WATER DISPENSER WORKS KITCHENAID SUPERBA MODEL #KSCS23INBL00 SIDE BY SIDE WITH ICE AND WATER DISPENSER IN DOOR
First check to make sure the icemaker is on. Most icemakers have what looks like a wire that extends to the right. Down is on, up is off. If yours does not have this, there might be an on off switch on the icemaker itself. If the wire (bale) is on, or the switch is on, then the icemaker is defective, unless the freezer is too warm. Icemakers have a thermostat in them that will not let them operate if the freezer is too warm. Sometimes that thermostat will not activate until the freezer is 15 degrees.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Keeps making ice, i can't seem to make it stop.
You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not making ice
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Dec 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Nov 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker
IT DOESNT MEAN YOU GETTIN WATER IN THE WATER DISPENSER THAT THE VALVE IS OK.MOST FRIDGES ARE FITTED WITH TWO VALVES.CHECK THAT THE ICE MAKER VALVE IS WORKING IF THATS OK YOU MIGHT HAVE A PROBLEM INTERNAL ON THE ICE MAKER BEST YOU GET A TECHNICIAN TO CHECK THAT.GOOD LUCK.MOHAMED
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
3,198 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
