Question about Canon PIXMA MP160 All-In-One InkJet Printer
Offline printing from computer
When I want to print from my computer the computer says I am offline check cable leading to computer and my printer I have an Canon Pixma MP160. I really need this problem solved , I need to print my school work, and my son needs this also.Please Help Me.
  • laughs Oct 21, 2008
    The solution you suggested did not work what should I do now
    I still cannot print from my computer I changed the USB ,It is saying offline what other solutions do you have or you just dont have any others.
    President:
  • 2,712 Answers
Check this first:
Click on START > Printers and Faxes.
Right click on your printer and select "Use printer Online" and try to print.
If the error still occurs, check the connector cable b/n PC and printer. If possible, try to replace cable. Check power supply and cables and make sure that the printer is actually ON. If all fails, try a different USB port and reinstall the printer driver after uninstalling it first...
Let me know how it goes.
Posted on Oct 20, 2008
  • Swilin Sampson
    Swilin Sampson Oct 21, 2008
    Have you tried reinstalling the printer driver? Power down the PC first, then reboot. Now switch on the printer and go to start>printers and faxes and see if you have "Use printer Online" or "Use printer offline"
    If you see the former, click on it once and try to print. If you see the latter, then there is a problem either with the driver or the connecting cable.
    Genius:
  • 1,847 Answers
Is the data cable that you are using works fine. try a different one.
  • Legin Varghese
    Legin Varghese Oct 20, 2008
    Your printer is not communicating with the Operating System.
    First uninstall the printer. ( Make sure you have the printer driver disk )
    Make sure the printer is OFF and disconnect the power lead to your desktop or laptop.
    Leave the computer OFF for 2 to 3 minutes. I actually mean turn it off
    and disconnect your power cord to the computer. That will clear
    everything.
    Plug in and on your computer and let it boot up. When its fully booted,
    click START / SETTINGS / PRINTERS and FAXes and click ADD A PRINTER.
    Follow the instructions and have the appropriate driver disk or files on your computer to complete the installation.
    Remember, most installations require the printer NOT be powered up or
    connected while you load the drivers. That is normally the last step
    and the driver loading will prompt you to turn on the power and make
    the connections.
    Hope this helps
    Kevin
    Then you probably will have to reboot and voila, you're done.
  • Legin Varghese
    1. Is the USB plug securely plugged into your PC (and the nack of the printer). 99% this is the answer.
    2. Unplug your Printer (and I mean actually unplug it from the wall) and then plug it back in.
    3. Your printer may be broken (1% of the time)
    Kevin
    Genius:
  • 1,124 Answers
Disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
  • Pablo Csaky
    Pablo Csaky Oct 20, 2008
    Disable your antivirus program and see what happen. Usually the antivirus is blocking the printer.
Printer is offline. how do I get it online?
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online. Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Feb 28, 2011 | HP Office Equipment & Supplies
Computer says "queue is offline"
Check:
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
Also on the computer:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
Jan 21, 2011 | Computers & Internet
Hp 4650dn printer showing offline. Connected through airlink router. Working fine one day, offline the next. Power cycled and checked all connections, still no luck.
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Jan 06, 2011 | HP LaserJet 4650dn Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
It is offline and will not print. Last print job
check the printer cable, try to change with other cable, or you can try to reinstall your printer driver.. hope these will help
May 04, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Not printing after a jam
Turn on printer and computer. Remove usb cable of printer from computer. Wait 1 minute and then reconnect usb cable to the same usb port.
Aug 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Photosmart C4580 All-in-One InkJet...
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
191 people viewed this question
old marine
old marine
