VCR does not record when programmed to do so
I just picked this up from a thrift store. I programmed the clock to know that it's 10/20/08, and 6:15. I then programmed a recording to start on 10/20 at 6:18 and stop at 6:20, and turned off the VCR. However, at 6:18, nothing happened. When I turned the VCR back on at 6:21, the program was gone.
I have checked after exiting out of the menu to make sure that my program is still there, and it is. I have also tried leaving the VCR on during the time when it is supposed to record, but nothing happens.
The VCR does record properly if I just push the record button.
Any ideas on how I can make this work?
  • 1 more comment
  • Sorkaa Oct 21, 2008
    Yes.
  • honeybebe Dec 23, 2008
    I did the Same thing you did second hand, won't record only play so i don't have a clue on what to do except piched this to the trash and buy me a new one with no problem. nechell13@hotmai.com
  • jason May 11, 2010
    does it play tapes?
  • 905 Answers
Is there a option to turn timer rec on/off?
Posted on Oct 22, 2008
  • jason Oct 22, 2008
    if thats not the problem then there is a digital chip or component preventing it from starting the timer
    then it would have to be tested to determine the exact component orr chip that has caused the malfunction
    electech
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
How can I process only audio through the unit successfully?
Somewhere on the menu screen will be a setting that switches the Tuner sound off so you can switch to the line input. Look under the sound menu if it has one. I can't tell you what setting or button to push as I don't know the model. Earlier VCR's had a simple switch on the front or back. But some stupid designer thought it would be better to put it on the menu system!
Apr 30, 2013 | Emerson DA-4Head VCR
I can't find my receipt & the manual doesn't say any dates. I'd just like to know how old my vcr is to find out if it's worth repair. Thanks.
This VCR is a 2003 model. You can find a used VCR on craigslist.com or a local thrift shop. You could also get a DVD recorder.
Jan 15, 2011 | Sharp VC-H810U VHS VCR
The year on the "clock
Yes, 2005 and 2011 are identical, the VCR will never know the difference. For future years 2012 and beyond just make sure the year you pick is not a leap year and that the day starts on the same day of the week for both years. The calendars need to have the same days and there are many years like this. Also check to be sure your VCR programming is good before doing a timer recording. You would not want to lose a show due to bad setup. See this link to 2005 and 2011 calendars.:
http://www.financialexpress.com/news/2005-calendar-to-repeat-in-2011/730787/
2005 calendar to repeat in 2011
Jan 12, 2011 | Sony SLV-440 VHS VCR
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
Toshiba SD-V295KU DVD/VCR Setup
Hi, David.
This unit does not have a TV tuner built in. It can record only from a video/audio source such as a satellite receiver or cable box. That's why you can't find anything in the manual about programming a channel. It doesn't offer that capability.
Not the answer you were looking for, but that's what they give you. The only solution I can offer is to keep your old VCR or pick one up at a thrift shop, and use it as the signal source. Program it to come on at the desired time on the channel you want, and use its video/audio outputs as the source for your recorder. Program the recorder to start at the same time.
Kinda klunky, but it would work.
Jan 30, 2009 | Toshiba 27DF46 27" TV
No remote for Goldstar 8mm VHS VCR recorder player
I have an extra remote to that unit if you would like to buy it. shesteasing@yahoo.com
Dec 06, 2008 | Goldstar GVR-DD1 VHS VCR
VCR won't record at programmed time
Check the clock to make sure the AM and PM setting is correct.
Oct 08, 2008 | Sansui Televison & Video
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
