Question about Goodman GMS90703BXA Heater
ROLLOUT SWITCH KEEPS TRIPPING
MY NEW GOODMAN PACKAGE KEEPS CUTTING OUT ON THE ROLL OUT SWITCH. THIS IS A NATURAL GAS HOOKUP
  • 1,420 Answers
Make sure the return air ducts are large enough, check the air filter for debris, has the gas pressure been tested? Is the room air blower turning and is it turning fast enough?
Posted on Oct 21, 2008
Rollout switch open displays
Fusible link or the Roll out switch are one and the same...
if it burns out, or provides 'Open Circuit', then you had heat or flame exit the front of the heater instead of up!
This is a problem that needs correction.
Most common reason, Sooted Heat Exchanger / Tube Bundle.
dissassemble and clean it - not with a brush!!!
2nd possibility, especially if outdoor installation is a 'Downdraft'.
Don't just replace rollout switch - FIX the reason it burned out!
May 24, 2015 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How can i fix a model raypak 406A natural gas pool heater with a rollout switch open indicated?
replace but find out why either inproper gas supply which will soot up and overheat and burn that part or if gas is ok then see if wind caused it to roll out then add a wind stack
Aug 17, 2014 | Raypak 406A Digital ASME Natural Gas IID...
Why condenser won't start board flashes6times meaning open rollout
check your roll out with an ohm meter they should have continuity if not they have a reset button on top of the switch push it and this will reset them. If they don't have continuity they are open.
Jul 17, 2014 | Goodman Manufacturing Goodman DSXC180601...
Open rollout or open fuse on Goodman
the fuse is located in the circuit board in the blower compartment and the roll-out is located in the burner section and can be a reset-able switch style or the one time fuse link style which is a a small silver cylinder and is mounted in a ceramic piece and is held in with one screw. Both of these are mounted around the opening of the your burner assembly near the opening. This will be near the area of the gas valve.
Sep 24, 2012 | Goodman Manufacturing Goodman R410A 13...
Goodman down draft Gas furnace, red led flashes 6 times meaning on the list, A "Rolling Open" The forced air blower turns on, the burner fan turns on, No Glow plugs turn on at the burner box to ignit the...
Hello Try looking for a tiny TAN colored (button) near the front of the burner rack.It will have a wire in & out of it.In the middle there is a small tab/button.Push that in you will hear a click.That is the rollout switch.Check the vent/exaust pipe for blockage/draft to determine the cause of the switch tripping.The switch is a SAFTEY and repeated trips means there is a problem.
Sep 08, 2010 | Goodman Heating & Cooling
My heater works fine when its a little cold,when its freezing outside it heats for a couple of airs then it would come on and off fine but with cold air blowing.i looked at the codes it blinks 6 times...
do not adjust your gas pressure without an manometer or if you dont know what you are doing could be very dangerous. Roll out switches are manual reset if you have an open roll out on a Goodman furnace you probably have a cracked heatexchanger, get a qualified technician out there asap
Oct 06, 2009 | Goodman GMS90703BXA Heater
Flame rollout sensor keeps tripping
sounds like your burners need to be cleaned, you will need to pull them out and clean the rust out of them. the rust builds up on top of the burners and when you gas valve opens and fills the burners full of gas you will have a roll out of flames. hope that helps.
Dec 30, 2008 | Heating & Cooling
Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Dec 14, 2008 | Coleman Propane Forced Air Heater...
Goodman GMS90703BXA Heater Logo
1,092 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
