Question about Vtech IP5821 Cordless Phone
Using Phone Book
Have any one tried using the phone book option in this phone. It saves the caller number with out the '1' and if we use to dial the outside caller it will not go through because its missing the first digit '1' for non local calls. This phone gives the option to edit the name by inserting letters with arrow keys but for numbers it clears the digits from right to left so if you cannot memorize the string of 12 numbers you are out of luck in saving the number from a caller ID display.I read the manual several times looking for work around. Have any one found a way to use this useless feature.
  • Shenny Paul Jul 09, 2006
    I found the fix. Vtech customer care had the fix. By using the # key at the received call number will give you preceeding dial numbers like area code and the '1' it works good. Modify the number before saving it to phone book.
SOURCE:
rizla
  • 1463 Answers
SOURCE: saving phone numbers
hello tjfred.
try here see if your phone listed 5.8 GHz VTech® then click
more info link when you see you phone for the manual.
riz.
Posted on May 12, 2008
  • 44 Answers
SOURCE: phone numbers not showing on caller id LED screen.
disassemble the handset (if you can figure out how to get it open). Flip the LCD screen over so that you can get to the end of the wire ribbon. You want the end that is connected to the phone, not the LCD screen. Carefully use a heat gun or hair dryer to heat the cable being careful not to melt it. Your goal is to melt the glue that connects the tiny wires to the electrodes. When glue is melted use a pencil eraser to press the wires so that they make contact again. Let it cool and try it out. It should work well after that. Put your phone back together.
Posted on Jun 28, 2009
  • 53 Answers
SOURCE: How do you save names and numbers under phone book
Here is the link to the owners manual
http://phone.manualsonline.com/manuals/mfg/vtech_communications/vtech_communications_cordless_telephone_product_list.html
Posted on Aug 31, 2009
SOURCE: Need to delete a name and phone number from the
Not sure if this is the same phone, but when I enter a number/letter, the "Mute" button serves as a backspace/delete function. So what I did was go to Menu>Directory>Review, scroll to the contact I wanted to delete, and press "Mute", which asks me to confirm to delete the contact. Hope this helps.
Posted on Dec 27, 2010
  • 24 Answers
SOURCE: I have a Vtech dect
For this problem contact your mobile service provider.....
Posted on Aug 25, 2011
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
Using speed dial with an LG Neon
if you already have contacts in your phone book and you have follow the set up info given...its just like retrieving your voice mail you normally would press the number "1" key...lets give it a test run press the number 5 key down for a second or two and release...it should be dialing whoever is in the the #5 spot...you just place your first speed dial....try it again lets call that number 9 ...note you can always change the positions (callers) in your speed dial..just simply go to the phone book to who you want to replace (eg.you want replace Debbie #4, go to Sam... options/speed dial/ #4 this will over ride who is in that position)
Jul 03, 2010 | LG Cell Phones
How to store a number in memory
hi,
you dial the number on your phone.
press the option button and scroll down to save number.
press save and the number will be on your phone book.
thanks for using fixya.
Jun 07, 2010 | GE 25932 Cordless Phone
How to put phone numbers on the blackberry 8120
you have 2 options. you can load them directly in your "address book" by going into your address book, menu button (bb icon left of trackball), select "New Address" and enter the info.
Option 2 , would be going into your address book, select "SIM phone book" and enter the info there.
Keep in mind, when you use the SIM phone book option, you can only enter their name and phone number, and after you are done, you have to import your SIM contacts to your address book.
Any contacts saved using the SIM option, will stay on your SIM card.
Any contacts using the Address Book option, will only remain on the phone, and not on your sim card.
ho[pe this helps!
Oct 30, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
Ka08 sms message settings
Hello, I had the same problem, but i figured out how to get the callers id/information. On the main page select Call Center>>Call History>> SIM1(or whichever you are using)>> and select either the Missed/Dialed/Received calls. Lets choose Dialed Calls for now. Select a phone number that you recognize>>select OK>>Options>>Save to Phonebook. In here you will create a new contact. Make sure you delete this old contact information from your phone book. (so you don't have doubles if already saved to your contact list). Now you can go to your main menu again and select the phone book option. Select the contact you have created and add a photo and ring tone you like. Now when you get a call you get their photo and rign tone. For sms you get only their name, but thats good enough for me.
Jun 26, 2009 | Apple iPhone 3G
CECT KA08 Caller ID/Msg ID
Jun 24, 2009 | Dual Electronics CECT P168 Cellular Phone
How do i find numbers that are saved to my sim?????
Most phone have settings to display, only sim contacts or only phone contacts or both
the user manual explains it and it is available in the following link
http://downloadcenter.samsung.com/content/UM/200810/20081030012522500/att_a867_eternity_ug.pdf
Address Book Settings
1. Touch ➔ Address Book Address Book Settings.
2. Touch any of the following options to activate a function:
• My Business Card: attaches a user created virtual business card
as an attachment to outgoing messages.
• Save New Contacts to: defines the destination for new contact
entries (Phone or SIM Card) (page 95).
• View Contacts from: to filter the display of current Address Book
entries. Options include: All, Phone, or SIM Card (page 91).
• Own Number: to display your current phone number (page 93).
• Fixed Dial Contacts: assigns phone numbers as FDN entries
(page 93).
• Used Space: displays the memory storage allocation (total available
and remaining) within both your Phone, SIM card, and FDN list
(page 97).
Hope this helps !!!
Apr 18, 2009 | Samsung Eternity Cell Phone
Vtech IP5821 Cordless Phone Logo
37 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
