Question about Miele DA220 Kitchen Hood
Lights not working
In an electrical storm, the halogen lights flashed a bright light then all went out. I have replaced the bulbs but that has made no difference. Power still comes into the unit and the fan operates. The switch for the lights indicates green yet the lights do not light. To me it appears to be the transformer for the lights has gone but I am not sure where the transformer is to remove and test it. I have removed the filter screens and can see the fan housings and a variety of components but none is obvious to be a transformer and I was hoping to avoid removing the entire interior electrical components to locate it. Can you help to identify what the possible problems could be and if it is the transformer - where is it and what does it look like? Thanks for your help.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Either the light power supply or a board gone. Haven't worked on one of these for ages. From memory, they are a pain. Miele appliances are difficult to repair if you are not trained. You may have to drop the whole unit to get to the electronics. Not hard, just a pain.
Posted on Apr 24, 2017
3 Suggested Answers
SOURCE: Miele DA270 Vent Hood Light Bulbs
I just bought two at Home Depot for around $7 each. I, too, saw the inexpensive internet ones and decided to spend the extra money and look at them first. I bought bulbs by Philips, called Desk & Cabinet (for enclosed bulbs). They are 20W and 12 volts as you said. It's a G4 Base T3. Now that I have these, I'll likely buy the cheaper ones next time.
Posted on Apr 05, 2009
Asbestos 56
  • 191 Answers
SOURCE: the lights and fan didn't
There may be a reset, but it may be due to a power surge burning out the controller board.
Posted on Jun 24, 2011
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
Bright went out after replacing the headlight
Replace with new bulb you must not touch the glass part of the bulb.oils from fingers will cause it to burn out, also make sure that there is no condensation inside of the bulb housing as this will cause the bulb to short out and possibly cause a fire
Apr 07, 2014 | 1999 GMC Sierra 3500
Flood lights in back yard not working
Which kind of flood lights? Long time lighting during whole night or security lighting sensitive to people walking across.
If it is for long time lighting, you should select the fixture lighting source as compact fluorescent, led or small wattage HID lamps, this kind of fixture you do not have priority requirement for instant on, the following fixture is just for reference.
http://www.bulbspro.com/vista-10040-35w-hps-wall-fixture-w-photoelectric-eye-bronze.html
For security purpose, you need the flood light right away reach full brightness, normally you take following fixture with halogen bulbs.
http://www.bulbspro.com/vista-10031-motion-sensor-twin-light-control-kit-white.html
Nov 10, 2013 | Dishwashers
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
I have two dimmer switches in the same box side by side. one goes to three pot lights, the other goes to a halogen track light. these have been working for 5 years. the lights have burnt out and been...
Sounds like the transformer in your track light. In the box where the green light is, the voltage is converted by a small transformer from 120v to 12v for the halogen lights. With the breaker off, try jumping out the dimmer going to the track light (disconnect the dimmer and connect the two loose wires from box together). With the breaker back on, if you have 120v power on the wires (black/white) going into the track light transformer (measured at the track light), and the green light won't come on, I'd say it's the track light transformer. You may have to replace the whole track if you can't get the transformer as a part.
Apr 22, 2017 | Lutron ELECTRONICS MAW-600H-LA SMART...
Can you replace standard headlights with halogen (bright white) headlights on a 1999 328ci? can you replace 16" wheels with 17" wheels on a 1999 328ci and does that affwct the...
Halogen lights will draw more voltage than the standard lights and will more than likely cause electrical problems by wires and switches and such getting overheated.
Larger tires will make your speedometer read that you are going slower than you are actually going.
Dec 26, 2010 | 1999 BMW 328 Series
Both my headlights went out. the fuses were checked and that wasn't the problem. what could it be?
Hi My name is David.I will assist you.
#1) Check to see if they work on Bright 1st and that your tail lights are working:
#2) If the don't From Under Hood where head Lights are Mounted CK to see if you Connections are on Securely.
#3) Pull off the Electrical Connection, Look for any Corrosion. Cleam the Terminals;Then try turning them on again.
#4) If they don't come on and your tail lights work but you have no Low or High Beam on Head Lights.
#5) I would go get a couple new Halogen Bulbs if they come on Problem Solved.
#6) If all the Above Fail Check all you wiring connetions to Battery, Make sure they are Clean.
#7) Its has to be your Head Light Switch.
#8) To replace you'll nedd to remove your Instrament Cover or Panel, To get to the Swith,Once removed.
Remove the Wire Connector and should be 1-2 Mounting Screws to Remove the Switch..
TO INSTALL NEW SWITCH Reverse the removal of the Head Light Swith. This will Solve your Problem; Please Give a Rating on the Quality of Help i Provided Thank You ! Thanks For Using FIXYA. From d_hubbs
Jun 28, 2010 | 1999 Ford Explorer
Installed driver side headlight worked, an hour later both main headlights went out, when I went to check lights noticed that there was another headlight behind a little chrome cover that was out, could...
reasons bulbs keep blowning.your head light bulbs is halogen bulbs.dont touch with bare hands.the oils on your hands will make them over heat and blow.so use clean gloves on your hands when replacing the head light bulbs.if all is good.check alternator out put.it could be overcharging causing too much current flow through electrical circuit blowing out bulbs.use a digital volt meter hook it battery with car running battery voltage should be 13.5 to 14.5 volts. if it is 15 to 16 volts too many volts.alternator is faulty.due to lock out features turn off radio before disconnecting battery cables so you wont lose radio playing code.
Nov 24, 2009 | 2004 Honda Accord
1998 pontiac sunfire
As for your dash lights, and electric locks, check your fuses. If the blue high beam light on your dash comes on, but the headlights don't get bright, your bulbs have burnt out, and need to be replaced. They probably went one at a time, but you didn't notice until the second one went. If the high beam indicator isn't coming on, it's probably your switch.
Jun 17, 2009 | 1995 Ford Explorer
Miele DA220 Kitchen Hood Logo
Top Miele Kitchen Ranges Experts
Marvin
Marvin
PokMan
Level 1 Expert
ray gallant
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
