Question about Graco Simplicity Rock n Roll 330 Crib
Graco swing has very limited range of motion. It still "works", but something inside is damaged or fell off. I have taken it apart to see the parts in motion, and it all looks like it is doing what is should, and it doesn't look like anything is broken. But when the swivel pin moves, it moves in a wide slot that only contacts and causes the swing to rock at the end of it's motion. Does that make sense? It looks like a piece fell out, but I have not found anything on the floor . . . Can I buy replacement parts somewhere or fashion one that will work?
  • minassian Nov 13, 2008
    We have the same problem - we have been trying to find some where to buy replacement parts.
We bought a used swing (lovein hug). It was in super condition but we noticed the same thing where it would hardly swing. My husband, who seems to analyze things that don't work, took it apart to see why so much slop was in there. He couldn't find anything obvious why it was doing that, so he took a piece of small cardboard (off an oatmeal box) and wrapped it around to make it fit on both sides and wrapped it with black electrical tape and stuck it back in. It's hardly noticable. We also changed the legs around to make sure the legs make the swing lay back.
Hope this helps!
Posted on Nov 19, 2008
How to disassemble graco swing
First, take part the seat. It had buttons and what not so undo them and take it off the frame. 2nd: Take the mobile (where the teddies hang) part by pulling. From there you just pull things apart. You shouldn't need any tools.
I hope this helps a little.
Apr 27, 2012 | Graco Lovin Hug Swing - Erin
Pajero / Delica - How to take apart "female" or
A flathead screwdriver should be able to pry apart the female end of the latch. Sometimes the female end is glued together, or similar. In order to prevent damage to the connector, I would recommend you try using some tweezers or similar to pull the debris out. A bent coat hanger, thick piece of wiring, or similar may work as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 24, 2011 | 1990 Mitsubishi Montero
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Need a user manual for graco sweetpeace newborn soothing center
I received a Sweet-peace newborn swing and the A/C plug is pushed in. Is there a way to retrieve it? How hard will it be to take the swing apart and retrieve the plug? You can reach me at my e-mail at: dragonman34@mail.com Thank you for your time.
Nov 13, 2009 | Graco Baby Gear
Dropped something in printer
Best bet would be to carefully take the printer apart, and remove the object that fell inside. The more you use it with an obstruction, the more likely you are to cause permanent damage. If you aren't confident that you'll be able to get it back together properly and do not want to replace the printer, simply take it in to any computer repair store and they'll quote you a price. If there is no internal damage is should be fairy inexpensive.
May 05, 2009 | Canon i450 - Printer - color - ink-jet -...
Graco Simplicity Rock n Roll 330 Crib Logo
826 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
