Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Clean light flashing 7 times. Can't start the machine
The "Clean" LED light flashes in sequences of 7 time. The machine won't start. According to the diagnostic brochure behind the lower panel, after getting the machine into the diagnostic mode it will reset itself. I followed the instructions and pressed in sequence the Hi Temp, Air Dry, Hi Temp, Air Dry keys. All the lights went on and stayed on. Nothing else happens. How do I know when the diagnostic cycle is over? Do I need to press anything else? Or the cycle progresses automatically? I left it like that for 30 minutes and nothing changed. I finaly stopped it by pressing the Cancel key. I did that few times and still the clean LED flashes 7 times. I cutoff the power to the machine and reconnected it but still the Clean LED is flashing and the machine can't be started. Any suggestion? Thank you High temp, heat dry, high temp, heat dry" then closed the door firmly, and the dishwasher High temp, heat dry, high temp, heat dry" then closed the door firmly, and the dishwasher began running again! I am grateful for the advise! I called Kitchenaid and they said to have a repairman come out! Thank You so very Much!
  • Anonymous Mar 22, 2014
    clean led light flashing. I do not have a heated dry cycle.
  • 70 Answers
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Posted on Feb 19, 2009
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | Dishwashers
Clean light is flashing machine won't start
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 09, 2010 | Kenmore Dishwashers
My whirlpool dishwasher is flashing 8 times - I pressed and held the start button to reset and then pressed start again, it kicked in and started to fill with water and stopped again - any ideas.
Hello, I have a Whirlpool DWF A10. The machine starts then stops after a short while and the indecator light flashes 7 times. What does this mean? Any body come across this?
Jan 11, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Mod #gu2500xtpb1 clean light flashes 7 times
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats--
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence--
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes). You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Whirlpool 24 in. ADG7540 Built-in...
We have a kitchenaid dishwasher model#kud102irbl serial#FU1705420 Clean light keeps flashing on 7 times, waits a few seconds and flashes 7 times again. How can we repair this?? Dishwasher will not leave...
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Feb 26, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
-high temp wash
-heated dry
-high temp wash
-heated dry
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
For KitchenAid Whirlpool KUDS01FLSS0 -- When the clean light is blinking or flashing 7 times in a row and no other front panel controls will work, do the following:
push SaniRinse-EnergySaverDry- SaniRinse - Energy Saver Dry
(Try the Heated Dry button if you don't have a Energy Saver Dry button)
All the lights will then come on as this will put the unit into diagnostic mode.
Then, push Cancel after about 10 seconds. You are no longer locked out. Run the dishwasher normally.
References:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3976dc6fea92e1c385256fc4006611c9/$FILE/8178496.pdf
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
Jan 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
840 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
