Question about HP iPAQ H2210 Pocket PC
Bluetooth problem bluetooth in my ipaq hp2210, which i have been using for the last three years, is unable to turn on. whenever i click the bluetooth manager a dialog box appears saying: " The Bluetooth Radio failed to turn ON due to insufficient driver memory available." i have done a hard reset. and downloaded the fixes from www.hp.com. but still the problem persists.
Often i find that programs are to blame for using lots of memory. a hard reset generally closes most of them but i use ClearTemp to remove the registry dregs and unused shortcuts. http://www.pda-ppc.com/download/utilities/content/cleartemp.html hope that helps!
Posted on Jul 27, 2007
How to conect my hp ipaq h1940 to the computer
Instructions
    • 1
      Select the "Bluetooth" icon from the Today screen of your iPAQ h1940. Click on "Bluetooth Settings." Touch the "Turn on" button.
    • 2
      Select the "Accessibility" tab from the Bluetooth menu and select "Allow other devices to connect" and "All devices." Click "OK."
    • 3
      Click on the Bluetooth icon in the upper right-hand corner of your Mac. Click "Turn Bluetooth On."
    • 4
      Select "Set up Bluetooth Device" from the Bluetooth menu and click "Continue." Select "Any Device" and click "Continue."
    • 5
      Select your iPAQ h1940 from the list of devices and click "Continue." Input the passkey number from your Mac into your iPAQ.
    • 6
      Select the type of syncs you want with your iPAQ and Mac and click "Continue."
    • 7
      Select "Browse Device" from the Bluetooth menu on your Mac and select the iPAQ from the list. Click "Browse."
    • 8
      Add or remove files from your iPAQ h1940 by clicking on them and dragging them into a file on your iPAQ or on your Mac. Close the window when you are finished and select "Turn Bluetooth off" from the Bluetooth menu.
    • 9
      Click "Turn off" on the Bluetooth icon on your iPAQ h1940.
hope it will help you..
monchi
Oct 17, 2011 | HP iPAQ H1940 Pocket PC
Compaq iPAQ 3850 Not charging/turning on
Try this - don't give up Leave it charging, even if it takes three days. I sold one a few years ago on ebay and the buyer was insistent it wouldn't charge. Eventually it did start charging and there were no more problems.
Jan 24, 2009 | Compaq iPAQ H3850 Pocket PC
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
Regards
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
Activesync via bluetooth
Click on Ipaq wireless
turn on the blutooth
Click on Manager
at the bottom click on new
and then click active sync via bluetooth and go from there
Jan 02, 2008 | HP iPAQ HX2490 Pocket PC
IPAQ 6500 problem
buy a new back and buy a new battery
Dec 13, 2007 | HP iPAQ hw6515 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
IPAQ rx3100 series
old mixed with the new. this toy PDA is 14 year old today.
do you own the router or the ISP or phone company?
you mean wifi, wireless has many forms!
the new router is using security that the old IPAQ cant do.
you have 2 choices
1: change THE ROUTER to weak encryption (and risk all other computers using it)
2: or get rid of the IPAQ, they are junk now. old and obsolete and no support, HP retired them, as legacy status.
if your read the manual for the IPAQ, it clearly shows its limits.
lots.
spec. 802.11b
WEP 64/128-bitcompliant to IEEE 802.11Compliant to 802.1X (EAP-TLS,PEAP)WPA
see the lack of WPA2?
if you set up your router to be wpa2 only as most folks do for
max security and ISP do,, no IPAQ like this works.
to others reading the battery just pops out on this newer model
then see a white sticker that sticker shows if your PDA
was opted with wifi and or bluetooth, there.
on the pda menus , labeled WIFI
make sure all off is not set to on, on main screen
click settings.
chapter 7 in the manual covers this.
turn it on
turn off ipaq wifi power saving mode, or it will fail.
the 3 lines in read below
must match your routers setting.
for example min router has WEP turned off so i cant get hacked.
wep is no longer secure.
pda-p0syz24ik43idjojxsw3jniu-4-0.jpg https://www.manualslib.com/download/850185/Hp-Ipaq-Rx3000-Series.html
it can connect
but the rules are very restrictedhttps://www.manualslib.com/download/850185/Hp-Ipaq-Rx3000-Series.htmldu,
Feb 12, 2018 | HP iPAQ RX3100 Pocket PC
Bluetooth Mouse for IPAQ
Yes, see this review from Dave's Ipaq..... http://davesipaq.com/articles/iPAQ_technology_Think%20Outside_Stowaway%20 Bluetooth%20Mouse.html
Sep 14, 2005 | HP iPAQ H5555 Pocket PC
How do I change the language of my Ipaq HP2210
You CANNOT change the language on an IPAQ. If someone can do it, I would like to know HOW... Good day !
Sep 14, 2005 | HP iPAQ H2210 Pocket PC
Hx 2415 Beam receive and transmit
No, you won't see an indicator light. make sure that the IR ports are pointed at each other - they are in different places on different Ipaqs.
Sep 08, 2005 | HP iPAQ HX2415 Pocket PC
HP iPAQ H2210 Pocket PC Logo
252 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
