Question about Kenmore 24032\24036 Top Load Washer
Spinning cycle IT makes a ticking sound like there is a zipper banging against the side. The light flickers when this is happening
    Scholar:
  • 121 Answers
Depending on what washer you have, what model. Some are easy to open some are not. But there is something between the inner and outer tub. The inner tub is where you put your clothes in with holes in it. The outer tub holds the water in the machine. I've pulled things that you wouldn't believe out of there.
Posted on Oct 21, 2008
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Samsung WF231ANW VRT Loud and aggressive spinning, banging against the wall
You have to make sure the load size is the exact match to what size your load is.
Aug 22, 2012 | Samsung WF231ANW 3.5 cu. ft. High...
With my Asko W6461, Right as the spin cycle starts, it sounds like something hard is banging against the drum (outside it) but inside the washer. Often, the spin cycle then does not complete. When I turn...
buy a new machine,the spider gear is broken and it's around 500 bucks for the part,you can buy a new washer for that,you used to much detergent,it eats at the metal on the spider gear and it falls apart,i've found parts of it inside the pump before.
Oct 19, 2010 | Asko W6461 Front Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Zannusi fl 1082 very loud banging noise when spinning
This is most likely due to an unbalanced load. The drom on the washer is only mounted at the bottom and if your load is heavy on one side, when it spins, the centrifigual force will make the inner drum hit the outer and bang. When you hear this happenning, open the lid, drag some of the wet items from the heavy side to the light side and close the lid again. The banging should go away. If you want to see what is happenning (though you MUST BE CAREFUL when doing this), activate the spin with the lid open by suing a stick or small screwdriver to press on the switch that is normally depressed by a post on the lid. The unit will 'think' the lid is closed and will resume its cycle. You should see the major wobble during the spin. NEVER PUT YOUR HANDS IN THE WASHER WHILE IT IS MOVING>
Aug 21, 2009 | Washing Machines
Loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
May 12, 2009 | Washing Machines
Banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
May 09, 2009 | Washing Machines
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Banging noise as dryer spins, wore hole in side of dryer
I need to know your make and model number in order to give proper advice. Joe
Nov 07, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
