Question about Danby Refrigerators
Enregistrement d'un appareil - Danby Refrigerators
  • 750 Answers
Hello danielpont,
Welcome,
Can you ask your question in english?
And be complete with the model number and year of the appliance!
Huuum
Posted on Oct 20, 2008
How to remove evaporator cover from inside freezer admiral model hmg64184
Hello Joann Carter,
Make SURE you are electrically UN-PLUGGED.
The repair books tell you to remove all the side rails... pull the screws... Disconnect the temp sensor (if equipped in this area (here you want to start taking lots of pictures))...
The thing is... removing the side rails is usually un-necessary...
A little clever negotiating of the flexible panel... and it can be MANUVERED AROUND (my opinion)...
Further opinion... after a complete open air defrost
(never apply heat (anywhere))... FANS will help... It is possible to blow air UP the defrost drain... & clear it.
Again... Verify you are electrically UN-PLUGGED.
Then negotiate some warm water (never hot) into the
Evaporator-drain pan... Success will be immediately
apparent in the defrost pan...
May take a couple of tries... (straw or flex tubing).
Only failing that... pull out the back panel .
Hope this helps!
Aug 21, 2016 | Maytag Admiral 26 cu. ft. Side-By-Side...
Parts, manual, replacement
Some have said the GE will howl, LOL! not much you can do for that should it be the compressor but if a fan you can. I believe I answered you on another page. HERE
Appliance 911 Sea Breeze
Nov 25, 2015 | GE Refrigerators
ALARM AL-15 ON CARRIER REEFER
hola qtal como estas, tengo un problema con un reffer de carrier modelo thinline con motor resiprocante que me da alarma al 15 y para el equipo no baja ninguna llave solo protege
Jan 08, 2012 | Carrier Refrigerators
Funziona 10 minuti poi si accendono e lampeggiano insieme la spia verde timer e la spia rossa turbo, se spengo e accendo di nuovo riparte e si ripete il guasto sempre dopo 10 minuti
Ciao.
Il frigo ti sta dicendo che non riesce a rafreddare come dovrebbe. Il caso piu comune e' dovuto a sistema di defrost che non funziona.
Prova a eseguire un defrost completo, staccando la spina (o l'interruttore) e lasciando il frigo staccato con porte aperte tutta la notte. Se questo risolve il problema allora era il sistema defrost. Se il problema ritorna in un paio di giorni o settimane devi riparare il sistema defrost. Il sistema defrost e' situato dietro la parete in fondo, di solito nel compartimento freezer. Il sistema comprende un evaporatore, che e' una resistenza che riscalda le spire del condensatore per prevenire congelamento. Il sistema comprende anche un termostato e una ventola (non quella di refrigerazione, un altra). Se il problema sparisce con defrost e ritorna in un paio di giorni queste parti vanno controllate. I test si fanno leggendo le resistenze delle singole parti.
Se il defrost non risolve il problema, cause comuni per il guasto sono:
Condensatore sul compressore da cambiare.
Sistema ventilazione (se presente in questo modello) non funzionante.
Controllo elettronico della temperatura diffettoso.
Perdita di gas refrigerante.
Le parti relative ai guasti elencati devono essere controllate.
Inizia controllando se il defrost ha a che fare con il problema. Quella e' la causa piu comune per it tuo problema ed e' facile da diagnosticare, anche a livello utente. Usa il numero che trovi nel manuale per ottenere parti, per verificare stato di garanzia, o per ottenere un appuntamento con un tecnico.
In bocca al lupo.
Ginko
Aug 10, 2011 | Refrigerators
Bonjour liebherr kes 3660 congele les aliments merci
Bonjour, J'ai le même problème. Avez-vous trouvé la solution ? Savez-vous où est le thermostat sur cet appareil ? Merci Cordialement Eric
Dec 11, 2010 | Liebherr KES3660 Stainless Steel...
SUENA UN PITO
El pito es debido a un mal funcionamiento lo que tenes que hacer es llamar a un tecnico para que te cambie el Main Control Board, y con eso se iran los sonidos.
Jan 22, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Can't remove front vent to clean/vacuum grill/coils
To remove, push down on the top of it as you pull on it. This will un clip it so that you can remove. They are sometimes hard to remove but this is what you have to do to get it to un clip
Oct 10, 2009 | Whirlpool ED5FTGX Side by Side...
Manual for CBI8M/Ic/FAN
salve volevo una informazione ho acquistato un frigorifero da incasso diversi anni fa ma ultimamente siccome va e viene la corrente in casa mia il frigorifero si e scongelato il tutto anche dopo la corrente sia ritornata , ho chiamato un tecnico e mi ha riferito che il funzionamento e corretto cio? questo modello e cos? quindi devo staccare la corrente e aspettare circa 15 minuti ma e normale??
Sep 25, 2009 | Whirlpool Refrigerators
Handle removal
You would be better served to remove the doors, ready fridge to move,( empty, un-plug ) . Remove front grille, un-plug wiring to door dispenser, follow water line and un-couple at water valve, then two people remove phillips screws from top of unit have second open door and lift off bottom hinge. you can then remove lower hinge if necessary for clearance.It took me longer to type than this process takes. And to remove handles involves removing door liners, don't go there.
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
There is power as the fridge is ok but the freezer is not frosting
Esto es un ejemplo de texto, con un video de prueba
Esto es una prueba
Jun 04, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
79 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
