Question about Olympus Camedia C-770 Digital Camera
Not Zooming My camera has stopped zooming in on objects. If fully zoomed in or out, no matter what the object the picture does not appear any closer. Don't think it is the settings and tried putting them back on default, but did not fix it. Any solutions?
  • Jinxer Feb 16, 2008
    Same problem with me.. in addition when we switch OFF it goes into playback mode. Anyone knows any service center in bangalore and how much it takes to fix the problem.
  • 215 Answers
The lens assembly on the Camedia and many other cameras has a special motor to facilitate the zooming. It sounds as if your motor is actually working but it's not engaging the gears to drive the zoom in and out. It could be a fractured gear somewhere in that drive system. I wouldn't recommend pulling one apart. They are a mongrel to put back together the right way. Keep your eyes open on Ebay for your model with a busted LCD or fault not associated with the lens and do a complete lens assembly transplant. Something which is relatively easy to do as long as you take notes of where all the parts and screws go. If you get left with no more than 2 screws when you've finished, you've done well.
Posted on Jul 12, 2006
SOURCE:
No possibility to focus objekts
Your lens elements are not moving smoothly. Maybe gummed up.
Mar 01, 2012 | Konica Minolta DiMAGE Z10 Digital Camera
How do i the camera to take smaller pictures and if it is by using the zoom do I zoom in or out.. Thanks
Hi sportingnut4 ,
Thanks for the question ,
  1. If you mean by smaller pictures i.e. small in area you have to capture the images keeping the distance in perspective.
  2. If the distance between the image and camera is more , you would find the object being captures is small and if the distance is less , you would find that the object that has been captured is bigger.
  3. If you want to capture an object which is far away you can use the Zoom In function which would zoom your camera's lens in the object.
  4. If you have already Zoomed in , then to decrease the zoom i.e. to go away from the object as if you are increasing the distance between the object and the camera , you should Zoom out.
  5. Remember , Zoom out usually only works when you have already used the Zoom in function of the camera.
Hope this helps.
May 11, 2011 | Sanyo VPCE890 Digital Camera
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
While taking pictures at normal settings (without zooming), every image is coming blur ,but when we zoom.....then the image is clear. Please suggest how can we correct this setting ?
Maybe you should check the object distance setting in your camera (in FOCUS setting I think). If the camera have this setting, you can choose longer object distance for daily capturing.
Hope this help. (^_^)
Jan 08, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto focus.show the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Nikon Coolpix 5700 Over-exposure of image whilst zooming in brigh
I now have the exact same issue. When not zoomed or fully zoomed the exposure is correct, however when partially zoomed the aperture does not engage and stays fully open. So basically I cannot really use the zoom or the picture is over exposed. Note - actually about 2/3 mechanical zoom and on works, so I can use a bit of the zoom.
Suggestions?
Sep 20, 2009 | Nikon Coolpix 5700 Digital Camera
I have problems focusing my f8000sd fuji camera when zooming in on small things.IIf I try to zoom right in on a butterfly for example,it will not focus and I can't use macro and get closer in case it flies...
Use spot metering & focus when taking pictures of an object.
Set your camera to highest Megapixel setting, Only use max. optical zoom on the subject (do not use digital zoom) .U dont need to get close to object as you can edit/zoom/crop the picture using any photo software program afterwards .
Aug 09, 2009 | Fuji Finepix Z20fd Digital Camera
Celestron astromaster 114 EQ (problems zooming in)
Most telescopes do not have a zoom-- they have different numbered eyepieces that give different magnification-- you can buy a zoom eyepiece however.
From what you describe -- put the eyepiece with the LARGEST number written on it into the telescope-- this is the LOWEST magnification. Now focus on the moon and or a distant land object during the day-- once it's in focus -- nice and sharp-- replace the eyepiece with the next LOWER number-- for more magnification. AND-- refocus the telescope for that eyepiece.
Feb 11, 2009 | Celestron AstroMaster 114 AZ (50 x 114mm)...
Trouble when Zooming
well did the camera got wet???, if soo it needs the mainboard to be replaced, if not could just be the mainboard also, but if it´s the second one the repair centre will fix it for free if ?t´s under warranty
Jan 30, 2007 | Olympus Stylus 720 SW Digital Camera
Optical vs. digital zoom
It's important to understand this difference, as you could be disappointed with the results if you use one rather than the other. Optical zoom works like the zoom on a traditional film camera. When you push the button to zoom in or out, physical lens elements move inside the camera, reducing the field of view and making the object you're shooting appear closer. Digital zoom, on the other hand, has no moving parts. The camera interpolates a small portion of an image to artificially restore the file to its original size. Using its electronic brain, the digital camera analyzes what it sees and digitally zooms in, usually two or three times closer. Unfortunately, digital zoom also reduces the resolution of an image, so your picture will tend to be more pixilated than the same image taken with an optical zoom camera. If you're just snapping an image to e-mail to a friend, this loss of resolution won't be so noticeable. But in situations where the highest quality counts, skip the digital zoom and use your PC's image-editing tools to zero in on your subject.
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Olympus Camedia C-770 Digital Camera Logo
87 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
