Question about Dryers
I have a BEKO DRCS68W condenser dryer. The "empty water filter" and "clean dust filter" lights came on, so we emptied and cleaned the filters. However,the lights still remain on. The light inside the barrel does not come on. The machine seems to have frozen. We have unplugged it, but it still seems to have frozen. Any advice. The "start light" is on, but when pressed, it just beeps.
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a Bosch Exxcel
Go to nearest tools shop and buy the screwdriver
Posted on May 26, 2008
swami nathan
  • 208 Answers
SOURCE: the tumble dryer bip and
I want to first make sure that your dryer is serviced up. so i want you to do these steps.
Most of the problems will be resolved doing these......
As clothes are tumble dried, they drop fibres. Most of this fluff is trapped by the lint filter and this needs to be checked and cleaned regularly. Lint also builds up in the vent pipe and around the electric motor in the rear of the dryer.
1.clean lint filter
Wait until the dryer cools, open the door and lift out the lint filter.
Gently brush off lint using your fingers.
On many models, the filter may also be washed. Check your manual for instructions.
If the filter is damaged in any way, you should replace it.
2.Vacuum area where lint filter sits:
The area where the lint filter sits should be vacuumed .
Remove the lint filter, and use a narrow vacuum nozzle to remove dust and lint from the fitting.
3.Clean inside the tumble dryer:
1. Make sure the dryer is cool, switch it off and unplug it.
2. Unscrew the retaining screws on the back panel, and lift it off. Vacuum the blower area.
3. Also vacuum around the vent pipe connection.
4. Replace the back panel and refit all the screws.
4.Check tumble dryer vent hose:
8d2299a.jpgWait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe.
Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals.
If your vent pipe is punctured or damaged, you should replace it.
To avoid dryer problems,
Make sure the dryer is level and does not rock, and consult the manufacturer's instructions for the maximum weight of clothing to dry at one time. Also, make sure clothes have been spun-dry before putting them into the dryer.
This is just initial help,
Post your comments about how things turned up, Ill be giving suggestions based on your reply........
Thanx for using fixya,
Cheers.
Posted on Sep 27, 2008
barkencoa
  • 3463 Answers
SOURCE: Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Posted on Jan 13, 2009
SOURCE: hotpoint aquarius condenser dryer ctd00 - empty
The float switch within the plastic unit at base of machine has failed,shorted out Carefully prise the unit open Disconnect and identify the three tags Replace switch and attached lever Examine the insulation on the rear tags as they are very close Reinstate Red light will now extinguish pump will run when float operates hearers will come on
Posted on Nov 22, 2009
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    Hotpoint condensing dryer model TCFS93BGP. cleanfilter/empty water light keeps coming on after 3/4 minutes
    Hi, my dryer has 3 things to check out of which one is more hidden:
    - empty the water reservoir
    - clean filter in the door
    - clean condensor which is hidden below the bottom panel which has to be released through a button behind the door
    The last one is less obvious and more difficult to find/reach. Might need to consult the manual.
    Did you check all 3?
    Hope this helps
    Mar 25, 2016 | Hotpoint Dryers
    Empty water light, empty condenser
    I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
    Feb 04, 2014 | Hotpoint Dryers
    Beko condenser dryer
    check dampness senser may still have lint trapped around it
    also poss. stuck button on control board
    Dec 06, 2013 | Dryers
    I have a Siemens e44-10 dryer. It works for few mins and that stops. The light looks like. Up of water flashes. I cleaned all filters, and the water tank is empty. Can u help me?
    I had the same problem above. I tok the side panel off and disconected the float and cleaned it. I noticed alot of water mixed with dust. I used a dry cloth to get the water away and made sure the reservour was clean. I assembled everything and it is all working. Tips, make sure the condense tray is emptied after each Washington aswell as the dust filter. Clean out bottom filter once a month. This saved me having to buy a new machine and tok just half an hour. Phew, money in the pocket!
    Aug 03, 2012 | Dryers
    Model: LG Steam Dryers DLEX2501R Problem: Shows "Check Filter", while dryer still does the job
    do you mean a condenser dryer?, as steam is water doesn't dry anything to well, if it is a condenser dryer the check filter or clean filter light should always come on towards the end of the cycle (varies between models some have both clean filter and empty tank lights on at end of cycle just as a reminder to do so and some don't have any lights), it is simply a reminder for you to clean the filter after each use unless this is something that has only just recently happened
    Apr 17, 2011 | LG DLE2514 Electric Dryer
    Hello I have a Beko CRS 68 W condenser dryer (18 months old). I have cleaned out filter and Big unit at bottom ( Which I think is the Heater Exchange unit ) as instructed - However when we put a fresh load...
    Clean the exhaust line connected to the rear of the dryer.
    Run a load of laundry with the rear duct removed completely and see if the light comes on.
    Mar 10, 2011 | Dryers
    Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
    Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
    Apr 04, 2010 | Dryers
    Dryer runs no water enters condenser draw, empty water light on.
    Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
    Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
    Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
    If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
    This involves a complete strip down to access these components.
    Plz rate my solution.
    Thanks.
    Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
    Dryers Logo
    109 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
