Question about Canon PIXMA iP2200 InkJet Photo Printer
Canon IP2200 ports
Im trying to connect my cannon IP2200 to my usb port. I have a working cable and enough power so I know those are not an issue. I have the drivers and such installed but the PC and printer will not communicate over my usb. I tried goin in and adding it with the printer wizard but no usb port is listed in the port selection segment. Is there another way to add this port?
  • Whombatt_010 Oct 20, 2008
    I have tried another usb cable and other devices work perfectly in the same usb port. I did reinstall the driver and upon rebooting a message poped up staing that a usb device had been detected and driver were installed. The device was ready for use. Imediatly after, however, another message poped up stating the device had malfunctioned and was no longer servicable. I know for certain the printer works as I recently used it on another computer. I will try to reinstall the driver with the antivirus disabled. Thank you for the prompt response, it was most unexpected and your suggestions most appreciated. Also I am running windowsXP service pack 3. I manualy ran the updates for windows prior to my first installation attempt.
    Brigadier General:
  • 6,966 Answers
Offhand, a couple of ideas, queries and suggestions:
  • verify the USB is enable in the CMOS/BIOS settings/configuration;
  • verify that there are no yellow or red markings in the Device Manager particularly the Universal Serial Bus Controllers;
  • try re-installing the printer drivers with your anti-virus temporarily disabled;
  • try re-installing the printer drivers with the printer not physically connected to the USB ports. Connect printer only when instructed to do so, Reboot;
  • update your Operating System;
  • pls humor me, tried a spare USB cable?
  • have you tried the printer in another PC?
  • have you tried other USB devices such as webcam, flashdrive, digital camera?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 20, 2008
  • Louie  Role
    Louie Role Oct 21, 2008
    Something just came to mind, some USB controllers could be powered down by the OS. Pls uncheck the feature "Allow the computer to turn off this device to save power" in all of the USB Root Hub Properties inside Device Manager.
I am trying to transfer pictures from my Cannon EOS Rebel T1i to my Mac book and I can't get it to work
When you connect the camera to the Mac, you must have the camera powered ON. THe Mac will automatically recognize the camera and will open iTunes to download the pictures. IF this does not happen, you may have a bad cable or a bad USB port on the Macbook. Try a different cable, or try a different port. Good Luck.
Feb 27, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Waste ink absorber is full
Hi there
Mar 14, 2010 | Canon PIXMA iP1600 Printer
Connecting WD Passport external HD with Belkin N+ router
I had this same issue. Found it to be a sequencing issue. Plug the USB into the router with the power off to the HDD. Power on the HDD and you should be able to get to it fine. Also make sure you have the latest firmware on the router.
Nov 27, 2009 | Computers & Internet
Waste Ink Absorber Almost Full
Download this utility
Unzip and run GeneralTool.exe
Select the correct USB port
Click lock release and your printer model
Click clear waste ink counter
Select main or platen
The selected waste ink counter will then be reset
Reset both especially if both have been replaced
Sep 01, 2009 | Canon Office Equipment & Supplies
It says the twain is not connected
check your usb cable is working fine .
Also check USB port on cpu works fine.
try all usb ports 1 by 1.
If stil same issue then uninstall driver then reinstall driver.
Let me know if you havent driver setup source.
Aug 24, 2009 | Canon CanoScan D646U Flatbed Scanner
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Cannot detect scanner
There is going to be issues with connecting it in this fashion. The usb adapters are not addressed the same as a real parallel port. This means that the drivers probably do not have a chance at working. The other issue is usb ports on laptops rarely have the power to drive devices larger than a mouse or keyboard. This means that the usb adaptor may not have enough power to function. Try plugging it into a powered usb hub then to the laptop. This may give it enough power to do what you want if the drivers are compatible of course.
Good Luck.
If all else fails goto goodwill and get a usb scanner. I always see stacks of them. Most are the usb type.
Feb 20, 2009 | Canon CanoScan N340P Flatbed Scanner
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Help
These units take more power than a thumb drive and sometimes the front USB ports on a computer just don't push enough current to recognize these players (I have the same issue).
Try plugging it into the back USB ports.
Also, make sure your USB ports are working correctly in your device manager.
Apr 27, 2008 | Insignia NS-DV2G MP3 Player
Canon PIXMA iP2200 InkJet Photo Printer Logo
52 people viewed this question
old marine
old marine
