Question about Mitsubishi WS-55809 55" Rear Projection Television
Code 2,2 TV stopped powering up, when I press power button it comes on for approximately 3 seconds, then shuts off. Reset produces no results. Holding menu and input indicates 2 flashes, then 2 more after a pause. Is this a fuse issue, a power supply issue, a capacitor issue, an IC issue, or could it be any of the above? I have limited electronics experience, can handle a soldering iron ok. Is this something I should attempt to fix on my own for the cost of cheap parts, or could I make it worse? Repair estimates range from $400 to $550, not sure it's worth that much to pay someone else to repair. Advice?
  • dcxguy48080 Oct 23, 2008
    could be blown fuses or bad STK...........i had the same problem and changed the STK and bad fuse and now the 2-2 error is gone but now i get 2-3 error lol
    oh well
Did you get this fixed? I have the same problem?
Posted on Nov 04, 2008
  • Mitsubishi Master
  • 8,617 Answers
On the center board you will see two green pico fuses F9A04 and F9A05 check those for continuity. If either one is open cahnge both the 5amp picos and replace the Convergence ICs. You can get replacement picos and ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Oct 25, 2008
Cannon MX340 printer - error code 6500
If the printer is not working properly or to clear memory try this:
1. On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the ON/OFF button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Or Try This:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, press and hold down the Stop/Reset button then press the ON/OFF button.
2. Once the printer is powered off, hold down Stop/Reset and then press ON/OFF.
Or Try This:
Reseat the printhead (printhead may also need replacing)
Aug 13, 2011 | Office Equipment & Supplies
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    How to resolve "P07" message
    Solution 1: If the device is not functioning properly or to clear memory, reset it.
    1. On the operator panel, press the button. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
    2. Wait approximately ten seconds and then press the button again.
    Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
    Solution 2:
    Step 1: Entering Service Mode
    * While the printer is OFF, press and hold the Start/Stop button (Resume/Cancel in some other models).
    * While holding the Start/Stop button, press and hold the POWER button.
    * When the POWER LED (green light) lit, release the Start/Stop button (still holding the POWER button).
    * Press the Start/Stop button TWICE (still holding the POWER button)
    * Release the POWER button.
    * Wait for the LCD to display "0′ (zero).
    Jun 10, 2011 | Office Equipment & Supplies
    How to resetter error p07 for printer canon mp258
    Mar 01, 2011 | Office Equipment & Supplies
    I lost the manual I need instructions to program it
    Manual Programming:
    1. Turn on the device with which you want to use the remote control.
    2. Locate a 3-digit code for your device.
    3. Press and hold the corresponding button on the remote control
    (TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
    4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
    5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
    Automatic Programming
    With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
    1. Turn off the device with which you want to use the remote control.
    2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
    3.Press and release power button. The POWER INDICATOR flashes once and stays on
    indicating the unit is in Power Scan mode.
    3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
    4. When the device turns on, press OK to store the code.
    5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
    Thank You
    Sep 12, 2010 | Hitachi VT-RM294A Remote Control
    I'm tying to copy, comes up with check ink u163 col
    It seems as though the ink counters are not being reset. Please follow the instructions below to reset your printer. Please read and follow the directions carefully as skipping any steps will not correctly reset your printer.
    1. Power off the printer.
    2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
    3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
    4. Release power button (the screen should now say 'Service Mode').
    5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
    6. Press the power button once, (the orange light should go off).
    7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
    8. Press the power button, and wait until printer has shut down.
    9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
    10. The page counter is now reset.
    Re-install the printer cartridges and give it a try.
    Aug 15, 2010 | Canon PIXMA MX310 All-In-One Printer
    My TV remote comtrol will not work when I try. I need the code.
    Hi.
    Manual Programming:
    Codes for orion TV are
    096,10,146
    Thanx
    Jul 27, 2010 | Brookstone 538744 Remote Control
    Getting a 5B00 error on a MX310. We just replaced the ink absorber
    error 5b00
    reset waste absorber counter. here is how to reset.
    1) With the printer2.gif powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button 4 times.
    If this does not work you need to call canon.
    Good Luck
    Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
    How do i program this remote to a mitsubishi tv?
    • Manually turn on the device you wish to scan for (e.g. TV)
    • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
    • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
    • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
    • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
    • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
    Oct 20, 2009 | Big Button TV Universal Remote
    Alarm light on and u051 error mx310
    Hi
    You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
    Please rate the solution & revert for further assistance.
    Thanks
    Rylee
    Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
    Mitsubishi WS-55809 55" Rear Projection Television Logo
    82 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
