Question about Liquid Video MVBG45 Portable DVD Player
Half the screen is dark
The bottom half of he LCD screen is very dark even with brightness set to max. The top half looks okay. The audio is fine. When viewing the video using an external monitor the whole screen is fine on the external monitor. There is nothing wrong with the DVD.
    President:
  • 3,130 Answers
Sounds like half your backlight is not functioning. The only thing I suggest is to call the manufacturer thats listed in your user manual and see what they think it will cost to repair unless its still in warrantee. There are no user serviceable parts inside of this unit so i dont think it would be a good Idea for you to attemt to take it apart as it may be a system to dissasembly and you make tear or break on of the small flex cables. Good luck
Posted on Jul 04, 2006
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Screen brightness adjust key
There is no key to adjust the screen contrast on the TI 30 XII S. You can try to reset the calculator by pressing 2nd 0.
It is possible that you have kept this solar-powered calculator too long in the dark. Give it some light.
Jan 01, 2014 | Texas Instruments TI-30 XIIS Calculator
Lcd tv half screen dark
my friend,your prossesor is not working the way it should be,thats why your half of the screen is dark and sometimes goes off, bring it repair shops and there'll get it fixed.
cheers
Dec 24, 2013 | Televison & Video
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
LG Computer Half Light, Half dark?!?!!?
Install the forteManager software that comes with your LG LCD monitor. Go to the Options tab and choose Restore which will set it back to factory settings. For some reason some monitors come this way out of the box and this was the only way I was able to solve the problem with mine.
Sep 18, 2009 | LG Flatron L1919S LCD Monitor
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
Televison & Video Logo
174 people viewed this question
Top Liquid Video Televison & Video Experts
Are you a Liquid Video Televison and Video Expert? Answer questions, earn points and help others
