Question about Hunter Fan Company 5/1/1 Programmable Thermostat
44860 thermostat won't activate in heat mode
I replaced a Honeywell CT3611 on a heat pump system. The AC works fine but the heat does not activate. The system setting is on heat pump. The controll wiring is a 6 wire system.
  • 3 more comments
  • Temieka Nov 02, 2008
    the heat wont come on
  • Anonymous Nov 12, 2008
    same here
  • flyjetboi Nov 15, 2008
    I have the same problem. The A/C & fan comes on, but the heat or fan does not.
  • douglas_corn Nov 16, 2008
    AC is fine, no heat at all??
  • pkien39 Jan 03, 2009
    indiglo thermostat, model #44550
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Posted on Oct 16, 2009
The board is showing that the heat is running. But it has not come on. I made sure that the overide is not set on the permanent overide mode
Posted on Nov 02, 2008
Replaced an Inter therm Thermostat Model # 65a-473-765b, with a Hunter Model 44860. The Fan works on everything but the heater. Heater comes on and runs for about 2 minutes but no fan, I manually turn on fan. I have tried to put it on auto and the Fan clicks off. Everything else works fine. Hooked up Red (with jumper RH/RC) ,White,Yellow and Green wires. I have 4 more wires that were not attached to old thermostat, Blue Orange Brown and Black. What do you suggest for my next move on getting heater to come on? Thanks Mike
Posted on Nov 16, 2008
  • 3 Answers
We had the same problem with a Rheem and a Honeywell thermostat and changed to the Hunter 44860. X is C and had to use the little jumper as in a single stage to get it to work. Made sure our span degree is 2, no less and fan set to auto.
Now here is the kicker...our white loops and goes to the emergency heat terminal as in the old thermostat. Is this coming on too?
Our heat bill jumped, but I am not sure if it had to do with the thermostat or whether is was because we had some unusually cold weather here in the south.
Currently, all is working as far as we can tell...on/off when supposed to. If we get another high bill, I will call the HVAC guy to review our wiring....never can tell if the old thermostat was right to begin with!
Posted on Dec 16, 2008
  • Soggy_Bottom
    Soggy_Bottom Jan 23, 2009
    Well, the saga continues. Noticed a burning smell about a day after our unit iced over. Turned air on to melt ice..no problem. 24 hrs later a burning smell..metallic/electrical, then it went away. Came back less smelly that afternoon. Call techn., fuses had some burnt spots, replaced, added freon. That nite, little smell, this morning, iced over. Is my thermostat wired correctly? They wouldn't touch it under my home warranty contract but looked at the diagram and listened to how we hooked it up.
    Got a call in today to them. If they fix it, I will post.
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Thermostat just stopped working.
is the tstat in cool mode? if not hit the mode button untill cool pops up then hit the down airow untill desired temp. sometimes the thermostat has a 5 min delay so be patent. If unit still does not run call the service co. and find out about how long they warranty their service call. usualy one month.
Jun 14, 2009 | Honeywell Electronic Programmable...
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Oct 24, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
3,495 people viewed this question
Top Hunter Dryers Experts
Fan Fair Of Boca
Fan Fair Of Boca
Paul Bade
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
