Question about Philips DVDRW 228 DVD+RW Burner
Driver problem with DVD/CDRW device driver
I have a Dell Inspiron 1200 notebook, it came with a Philips SCB5265 DVD/CDRW drive. I am having trouble locating a driver for this device, and the original one is not working properly. Please help.
  • 1 more comment
  • sandystell Oct 21, 2008
    Thank you for your input, I actually did that after I posted this and it WORKED!!!! Thank you so much.
    SStell
  • valan_aircas Nov 26, 2008
    I NEED THE DRIVER
  • Anonymous Apr 08, 2009
    lost driver
    Novelist:
  • 70 Answers
Hi sandystell,
Well normally in Windows XP the DVD/CDRW drive won't need anymore drivers, since Windows automatically installs one for it. I assume the problem you're having is that the drive is not able to read CDs/DVDs or burn a disc, correct?
If that is the case you can actually follow this microsoft KB article: http://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B314060
This will give you indepth help on what to do. I would recommend that you do the removal of the upper filters and lower filters in the registry.
You can test if the optical drive works in Safe Mode, by pressing F8 on startup and choosing Safe Mode, then logging into yourr account. See if the disc is read in Safe Mode, if it does, then you have a program that is conflicting with the drive. I would recommend that you run MSCONFIG, goto Startup tab and disable most if not all of the startup items, then click on APPLY then OK.
The next thing is running the diagnostics for the computer to see if there any reported hardware problems. Now if all tests passed, the next step is reseating the optical drive (if possible) check the computer manual on how to do procedure, otherwise you may have to call up Dell Technical Support.
Now you may have to replace the drive itself since it could be defective now.
Hope this helps!
Peace! :)
Posted on Oct 20, 2008
My laptop Dell Inspiron 1200 does not recognise my phillips cdrw dvd cdd5263 drive
Follow the following instructions:
1.) Start Menu
2.) Right-click My Computer and click on properties.
3.) At the tabs at the top, go to hardware.
4.) Click on device manager.
Once the window opens any device inside or connected to the computer will be under the respective groups. Anything unknown to the computer will have a little exclamation mark next to the icon. On most computers, if there are any the groups will already be expanded.
Once you've found the dvd drive that isn't recognised, update the driver by right clicking on the device -> update driver.
You do have to be connected to the internet but it sometimes searches the computer for the right driver. Hope this helped
Mar 22, 2011 | Microsoft Windows XP Home Edition
My disk drive is stuck and will not read the disk. How do I fix this?
make sure that the cdrw/dvd combo is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cdrw/dvd combo then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device ?
control panel admistrive tools,computer management,device manager scroll down cdrw/dvd drives?right click you can? you can update driver,roll back driver,or select properties general troubleshoot, select driver? click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 01, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
I need a to download a driver for Philips CDRW/DVD SCB5265. My installation wizard can't access the one I download from the dell website. Thank you.
first delete the driver then use the installation wizard to install the one you downloaded...
let us know what happens
Nov 25, 2010 | Dell Inspiron 2200 PC Notebook
Hello, installed Nero on my computer. I have a Dell Inspiron/E1705 Notebook. I am having trouble Burnind DVD's. When I put in the **** to record and go to burn the dvd the source drive says DTSSTCORP...
insert the cd into the driver
go to the setup wizard and click next next & next untill u find the option install
after clicking install
it will take only 1 or 2 min to be installed
Mar 11, 2010 | Dell Red Hat Enterprise LINUX WS Version 3
I have a Dell Inspiron 6000. I was recently
Remove the drive by turning the computer upside down and take the screw out between the battery and the memory cover (next to a padlock symbol). Insert the screw driver into the little notch in the plate next to where the screw was and slide it towards the drive. The drive should now pop out. Boot the computer. Shut the computer down and reinsert the drive and reboot.
Aug 28, 2009 | Dell Inspiron 6000 Notebook
PHILIPS CDRW/DVD SCB5265 ATA Device cannot play most DVDs
I'm guessing you may have locked the DVD region. If you right-click on the device in Device Manager and click the Region tab, does it say 0 changes available? Acer won't fix this, and claim you have to replace the drive. Can't find a firmware flash for this drive online, will post back here if successful!
Aug 14, 2009 | Acer Aspire 5535-5050 Notebook
Dell inspiron 1525 cd drive not recognizeing
ok what you do is go to control panel and system and then click ur driver and then install the dvd one
Aug 03, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
MY PHILIPS CDRW/DVD SCB5265 CAN READ CDs BUT CAN NOT READ DVD
I just installed Nero CD writing Software and Power DVD and it took care of the problem.
Jan 15, 2009 | Philips DVDRW 228 DVD+RW Burner
Philips DVDRW 228 DVD+RW Burner Logo
490 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
