Question about Samsung HCL4715W 47" Rear Projection Television
Blue convergence wiiltab any luck with the items we have discussed
    Genius:
  • 1,030 Answers
Sorry i havent got to shop ill see what i can do... im so sorry.have you tried the service mode? do you hVE ORIGINAL remote navigating in service convergence mode is the major thing. i want to say it the pmode button or the s mode. i want to see if blue will move
Posted on Oct 21, 2008
Convergence issue... I tried to manually fix it through the menu option without any luck. The convergence does curve at the top and bottom of the screen.
It seems the solder is broken in Vertical Convergence Amplifiers or it is damage internally. This model has 2 Conv. Amps: 1 for Horizontal (Red, Green and Blue) and 1 for Vertical Convergence output (Red, Green and Blue), if the convergence does curve at the top and bottom, it is because Vertical Converegence output is no good. The Conv. Amp. costs around 20 dlls. Thats why you can not fix it with the Menu option. Good luck!
Nov 13, 2009 | Philips 60PP9202 60" Rear Projection...
I have a blue shadow that outlines every image. the convergence of the blue cross does not seem to line up with the red cross as the manuel indicates it should. Also power has started to click off and on...
The problem is in the convergence system which can also cause the tv to not power up or intermittently turn on and off. About 50% of them are bad connections on the convergence power pacs. The convergence power pacs are easily located by the large heat syncs associated with them. The digital control board is located very close to the power pacs. Remove the circuit board housing the heat syncs and using high magnification look for rings around the pins of the convergence power pacs on the foil side of the board. Re-soldering up all the cracked solder joints in the convergence system including the digital control board should solve the problem.
If there are no cracked solder joints in the convergence system, or if repairing the connections does not restore the unit, the power pacs will have to be replaced. Ensure that you apply heat sync compound on the backs of power pacs or they won't last.
After replacing the power pacs, check all of the precision resistors for burn marks or detolerancing and replace as necessary. Next, although rare check the fuse links to the power pacs. This should complete the repair process unless there is some other atypical problem which is beyond the scope of this discussion.
Apr 27, 2009 | Toshiba TZ43V61 43" Rear Projection...
Step by step repair guide for blue convergence problem
Good Day;
Symptom: Blue convergence off, bowed inward at the top and bottom with No blue vertical movement.
Cause: Replace IK05 (STK392-110) and RK54 (2.2/1W) and converge.
Buy KIT10 at 1-800-458-6053, it contains all upgrades and parts needed for repair. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Samsung pcj522r
If they tested the convergence board and thats ok, the only other Items it could be are the Digital convergence unit or the Velocity comando units that control the convergence yokes. If the convergence isnt adjustable with magic focus adjustments wont help it. Is the repair shop an authorized samsung repair facility? If you need more assistance let me know.
Jul 26, 2008 | Televison & Video
Blue color lamp cannot converge
GO TO THE CONVERGENCE MENU (MENU 2 3 5 9) AND CHECK THE ADJUSTMENT SETTINGS FOR CONVERGENCE. IF ALL ITEMS ARE SET AT "127". THE EEPROM SETTINGS ARE AT DEFAULT.
Nov 30, 2007 | Mitsubishi VS-55601 55" Rear Projection...
50 " mitsubishi projection tv
This website:
http://www.techlore.com/forum/thread/18547/Mitsubishi-convergence-IC-s-used-in-the-differant-models/
says your model uses the STK393-110 convergence chip. Another site I looked at said that was a 6 channel amplifier so I'm guessing you only need one to repair your TV.
If you do some google searches on "stk392-110 convergence problem" you'll find some good sites that discuss how to repair the tv. The STK392-110 is a convergence amplifier that is used any many other sets.
Good luck.
Nov 19, 2007 | Mitsubishi VS-45609 TV
Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Sep 14, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Convergence??
Yes, thats does appear to be some convergence issues. You can find someone who works on there, such as an ISF calibration specialist. or they can recomend you on where to go. check out: lionav.com to discuss. good luck.
Sep 13, 2007 | Mitsubishi WS-65809 65" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Samsung HCL4715W 47" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
