If a hard reset does not fix, then your electronics may be bad.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
SOURCE: DLink DIR-615 can forward ports
You probably have a 3rd part firewall software on the PC, configure that firewall to allow the same ports. what AntiVirus do you have?
SOURCE: D-Link DIR-615 Internet LED light not working
Even though we need more info to resolve the issue, I will make a guess here. My guess is that your D-Link is not configured right, (ie. not pulling the proper info from your ISP's DHCP server.
Try restarting the router and restart or repair your network connection on your pc. Secondly, try to do a "hard reset" on the router, or restore to default. Then reset your connection on the PC. Third, manually set the info on the router.
If you are wireless, you have a whole different issue.
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
SOURCE: i dont know what the blue light is for on the side of my dir-615
Wow, it is not mentioned at all in the manual at http://static.tigerdirect.com/pdf/D-Link-DIR-615-Manual.pdf - in fact no lights on the side are mentioned at all.
My first guess was that the router had bluetooth but that is not true in the one I looked at.
Now there is a picture in the manual on page 7, and all the lights are identified. Maybe you can look at the pic and figure out which light it is? Although I would call the surface that all the lights are on the front, not the side.
