-   The bleach dispenser is not working. It is controled by a electronic solenoid.
-   Guest
Aug 13, 2008
-   I have a top loading Whirlpool Ultimate Care 11. My softener dispenser does not dispense softener -- how can I clean it? I have tried running the washer with hot water and bleach, and also trying to "unclog" the holes that usually have liquid draining from them. Nothing seems to be working.-   nbrekkelv
I did solve this problem. The hole where the water enters the fabric dispenser was clogged. I used a pipe cleaner and kept inserting it into the hole and pulling it out. Much gunk came out and the dispenser is working fine now.It was difficult to reach my hand in to insert the pipe cleqner but it worked,
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water enterence and distribution to drawer's cells (following the programmed cycle)are done by a lever's movment (part of the dispenser). The lever movment is controlled by two solenoids that received their power from the timer. By openning upper machine's cover you will have an access to the dispenser. Dissconect the power cable from the machine before moving to next tests !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movment). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
There is a pipe under the front loader shaped like the piple under your sink....and it gets clogged up with lint, tissue, hair, etc. I just has my washer fixed...the smell from the water (I thought) was actually a build-up of all of the aforementioned, lint, tissue, etc. and my repairmain sold be a product called Affresh It is a tablet like the kind you use in dishwashers only bigger I copied the information for your use...This works
Emily Robinson
Only Affresh ™ washer cleaner is proven to penetrate, dissolve, and remove odor causing residue from your HE Front Load Washer. It doesn't cover up the odor - its oxygenating action lifts the residue from the surfaces in your washer, allowing it to be rinsed away. Bleach temporarily removes the odor, but not the residue that causes it. Using Affresh™ cleaner is fast and simple - add the tablet to your washer tub and run a normal or "clean wash" cycle once a month. This routine maintenance will keep the inside of your washer sparkling clean and fresh smelling. Affresh™ Washer Cleaner removes and prevents odor-causing residue that can occur in all brands of HE washers. Affresh™ cleaner is a formulated, slow-dissolve, foaming tablet that gets under residue, breaks it up, and washes it away leaving the washer smelling fresh and clean.
Affresh™ brand is environmentally friendly, safe on septic tanks, and safe for all washer components.
Package includes three tablets. emoved the stuff for me and then. gave me a product called
the door lock light is on, but when I pull knob to start wash I hear a hum but no water begins to...
(More)
the door lock light is on, but when I pull knob to start wash I hear a hum but no water begins to fill?
