Question about JVC TH-A5 System
Loud Poping sound
I have not used my system in awhile, but when I turn on the power it hesitates a second then gives a loud poping sound and turns itself off. Wondered if this is fixable or if it is fried. Thanks
It sounds Like your power supply has developed a fault, advise not to use/or turn on untill problem is sorted
Posted on Jul 05, 2006
SOURCE:
My car turns over but it wont start in when i do click it over it gave me a loud poping sound what to do
look where you put the oil,if you see the cam have someone barely turn the engine over.Is the cam moving? Sound like you are back firing.
Dec 17, 2013 | Cars & Trucks
Vizio model vx322 hdtv10a is losing sound and makes a loud humming noise and a poping sound every few minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | Televison & Video
When i put 2500 into 4 high and turn the wheel left or right there is a loud ticking sound
if it has cv-axels in the front one or you cv-joints may be bad or a u-joint can cause a clunking or poping sound.
Oct 23, 2010 | GMC K2500 Cars & Trucks
Hissing sound when turned on and goes dark when sound stops.
takes long time for tv to come on, there is a loud buzzing sound and poping noise
Mar 16, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
The tv was on for about 2 hours when we heard a loud poping sound, and the screen turned black and will not turn back on.
Blown capacitor...
You may be able to do this repair yourself. I can walk you through it....
Jul 10, 2009 | Televison & Video
Loud poping and cracking sound
sounds like the high voltage problem from high voltage socket, check with an expert tech.
May 05, 2009 | Akai PT4298HD Rear Projection Television
Loud poping sound under truck when driving as up and down shiftin
Could be the ujoints ,just a couple of bolts that hold in UJoint...Have you checkes your trans and motor mounts?
Jan 23, 2009 | 1996 Ford Ranger SuperCab
No picture
sounds like high voltage arcing,/flyback,focus block,h.v. anode lead etc.
Sep 07, 2007 | Toshiba 55H70 55" Rear Projection...
JVC TH-A5 System Logo
64 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
