The mode dial is part of a larger assembly. Here's instructions on replacement of a similar S30. Don't recommend that you try this unless you have some familiarity with electronics, and a lot of patience. Above all keep track of all your screws as they're all different sizes:
If your Canon AV-1 is only shooting in Bulb (B) mode, it could be due to a malfunctioning shutter or aperture control. However, since the light meter is working correctly, it is possible that the issue is with the camera's shutter speed dial. The shutter speed dial is located on the top of the camera and should be set to a specific speed when shooting in aperture-priority mode. If the dial is stuck in the Bulb (B) position, then the camera will only shoot in bulb mode.
I would recommend taking your camera to a professional camera repair shop to have it inspected and repaired if necessary.
To exit the continuous mode on your Leica D-Lux 3 camera, you can follow these steps:
Turn on your camera and select the shooting mode by rotating the mode dial to the appropriate setting (e.g. P, A, S, M)
Press the menu button and navigate to the "Drive" or "Continuous" setting.
Select "Single" or "Single Shot" mode to exit the continuous mode.
Press the menu button again to exit the menu and return to the shooting screen.
Alternatively, some cameras have a dedicated button or switch to switch between single and continuous mode, in that case you can use that button/switch to switch modes.
It's also important to check the manual of your specific camera model, as the steps may vary depending on the camera firmware version and the model itself.
You need to set the camera's shooting mode to one of the remote modes. Quick-response remote mode fires the shutter when you press the button on the remote. Delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
To choose a shooting mode, press the mode dial lock release and turn the mode dial to the desired setting.
You need to set the shooting mode. Press the shooting mode dial lock button and turn the shooting mode dial to the desired setting. The self-timer is marked with a one-handed clock.
Hi, Prepare to Live view shooting: 1. Set the lens focus mode (on the side of the lens) switch to <MF> 2. Set the shooting mode to a Creative Zone mode 3. In menu under the settings tab, select Live View function settings and then press <SET> 4. Turn with quick control dial to select Live View shoot and press <SET> 5. Turn with the control dial to select Enable and press <SET>
With the camera ready to shoot, press <SET> - image will appear on the screen in real-time
This dial is the Mode Dial. It allows you to switch between shooting modes (still pictures and movies) and playback modes (allows viewing of still pictures and movies within and out of an album).
