Question about Dell 924 All-in-One InkJet Printer
924 message "printer is busy"
My Dell 924 printer responds "printer is busy" and "Check control panel" when I submit a job for printing. I find nothing informative in the control panel. The "printer is busy" message occurs whether or not any queued jobs are shown for the 924 printer. This problem showed up just after I changed the color ink cartridge. What do I need to do?
  • dellessor Oct 24, 2008
    I tried a number of times to re-install the 924 printer driver without success. Re-installation was eventually successful, though I didn't figure out why the previous attempts were not. I appreciate the volunteered efforts to help.
  • 1,124 Answers
Take out the cartridges
disconnect printer from computer
Turn off the printer
On the computer cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
Reconnect printer (swap cables if not detected)
Insert the cartriges
Try printing again
Have a great day!
Let me know how it is going
Pablo :-)
Posted on Oct 20, 2008
  • Pablo Csaky
    Pablo Csaky Oct 21, 2008
    Why are you rate my help as Innapropiate?
    Please explain or change your rate!
  • Pablo Csaky
    I'm trying to help you giving to you a solution to fix your problem.
No matter how many times I try to print something (& having gone through troubleshooting unsuccessfully) I get the message: - "The Dell AI0 Printer 924 is currently busy. Your print request will...
Uninstall the printer from the Device Manager. Dis-connect the printer from the computer. Reboot the computer. Re-connect the printer to the computer. Allow your computer to detect its' connection from Windows. If it is successful - it will indicate it is ready for use. If not, then there is a problem with the printer. Try another printer, if available, and see if that works - if it does, then it's the printer that's bad, not the computer.
Oct 28, 2010 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
When i try to print doesn't print and message shows in upper bule line'usb port not responding" what should I do?'
If you are using Windows Operating System, I suggest you do the following procedures.
  1. While your computer is turned OFF, unplug the printer's USB cable from the computer and transfer it to another USB port in your computer that is unused.
  2. Then turn your computer ON and Windows will try to configure it and install the drivers needed for your printer to run on the new USB port.
  3. If steps 1 and 2 above don't work to fix your problem, the last thing I can recommend is "uninstall" your printer from the Control Panel and restart your computer. After restarting, install your printer and try if it now works.
Jun 08, 2010 | Dell 924 All-in-One InkJet Printer
Dell Photo AIO Printer 924 - Printer Busy
Might need a new printer. Lexmark printers can be troublesome.
Jul 14, 2009 | Dell 924 All-in-One InkJet Printer
Why cant I access printer 924 user guide
just check out all the power & (plug & play ) ....
than search for optimal drivers all installed or not ? make it clear..... if not ! than complete u'r job 1st... than start your printing ....
Jun 08, 2009 | Dell 924 All-in-One InkJet Printer
Dell 968 printer not responding message please help
try unplugging the printer and plugging it back in, also do you have the printer set as the default printer
Apr 26, 2009 | Microsoft Office Professional 2007 Full...
Printer Problems
Uninstall the printer driver software completely and then download the drivers from the dell website for the Dell 924. Reboot the system and it should be okay.
Dec 02, 2008 | Dell Inspiron B130 Notebook
Installing ink cartridge
I've had this problem too. The only way to make the message go away is to buy the ink from Dell. Although generic ink cartriges will work the printer will not/can not reset the "low ink" message unless you buy the cartriges directly from Dell. So you can use another brand, but you'll just have to overide the low ink message when it pops up by telling it to continue printing. Then you can tell when the ink is low by seeing it when it prints out.
Sep 10, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Printer
Delete All has worked for me.
Aug 12, 2008 | Dell 924 All-in-One InkJet Printer
Printer busy message
See if this works:
Turn computer off
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the uparrow.jpg and downarrow.jpg (up arrow and down arrow) buttons on the printer and power the printer on.
  4. Release your fingers from the buttons when the message Diagnosing... appears.
  5. When Customer Mode and ESS Diag display, press the downarrow.jpg (down arrow) button until Test Print appears, and then press the select (center) button.
  6. Press the downarrow.jpg (down arrow) button until ContaminationChk appears, and then press the select (center) button twice.
  7. After the LCD displays Busy and the printer prints the ContaminationChk pages, power off the printer and power it back on.
Jan 20, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
286 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
