Connecting my computer directly to konica 8020
I don't have the right connection cords to connect the konica 8020 to my computer. Is there a way to directly connect to the printer, instead of using a router. my computer has an either net connection and a usb connection. My computer knowledge is very limited.
  • sam gerban
    sam gerban May 11, 2010
    8020 what ?
    is that a copier ?
  • 2,794 Answers
You can hook the copier directly to your computer using a USB cable.  You can purchase one at any computer store.
Posted on Oct 21, 2008
  • Tim Babcock
    Tim Babcock Oct 24, 2008
    You might have a parallel cable connection on there as well or either depending on how old the printer is.  You can get those at computer stores as well.
Hello friends How can I set up my computer win7 to the Konica minulta printer by network cable cat5 please answer very detail.Many thanks.
First, you CAN'T connect a CAT5 cable directly from your PC to the Printer. That won't work. Both have to be connected with their own CAT5 cables through a hub or router on your network. The router gives them separate IP (network) addresses so they can talk to each other.
You may need to set up the printer through a direct USB connection to your computer. Once the networking options are set, IF it's an Ethernet-capable printer you may be able to connect that way.
Jan 20, 2018 | Konica Minolta Office Equipment & Supplies
Konica minolta 350 touch screen stopped working
Similar problem with a Canon MG6320 has been solved .There is an updated firmware for this printer that fixest his issue. Download and run it on your computer that is connected via a USB cord directly to the printer.
Jun 16, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
What cords do I need to connect konica minolta to laptop
That a big machine, will only work with xp or before, try computer store
Jan 07, 2014 | Konica Minolta Minolta 7222 Laser Printer...
How do i connect phone to laptop connection
So do you have internet service at the house? If so you can plug the ethernet cable from the modem directly into the computer's ethernet port.
If you're talking about directly connecting to your cell phone, then the phone has to have the built in router in it. If it does, you can connect your computer to it wirelessly.
If you're talking about a regular old house phone (land line) then you would be very slow if you could get it connected. I don't think the newer models of computers even have a modem port to connect a telephone line into it. But basically you would still need a internet service provider to connect it.
Bear in mind that there is a difference between the phone cord and the ethernet cord. The phone cord is smaller in size and the end that plugs in is smaller.
Apr 03, 2012 | Computers & Internet
I need to connect my old speakers to my new Samsung monitor. No instructions in manual. thanks, barb
You don't connect speakers to the monitor, you connect it to the tower of the computer. If I'm not understanding your question right then please be more specific. If your monitor has speakers, you connect the audio cord to the tower then to the monitor or vise versa.
Jul 29, 2011 | Samsung Syncmaster 940BW LCD Monitor
I am using XP SP3. installed a game and it did put the wrong video driver file (Direct X) on my computer. Now window screen goes blank (no signal) after initial start up. I don't know how to fix...
Does your monitor have more than one cord?If yes one should be white,which you connect to your gpu.The other should be blue.The blue one is vga,and will connect directly to the mb.Turn off the pc and disconnect the white cord and connect the blue.This should get you a picture.Now down load the newest Direct X and install then power down and switch the cords back.
May 12, 2011 | Computers & Internet
How do connect the sh-8020 to a maantz reciver
sound source(cd or dvd)-----to equalizer input-------equalizer output------to marntz input(line in or tape in).
Oct 04, 2009 | Technics Audio Players & Recorders
The control panel is blank and I cannot find a diagram of the appropriate cables
Hello sir; There have a dial on the control panel either on leftend or rightend of the control panel. just twist it ,going to appear on normal.
Apr 14, 2009 | Office Equipment & Supplies
USB AV Interface cord
Any Camera store/Computer store sell those cords make sure you take the camera with you to get the correct type of camera end connectioor but a card reader - much more versatile.
Sep 01, 2007 | Konica Minolta DiMAGE X50 Digital Camera
210 people viewed this question
jasbo
jasbo
