I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after 20 minutes or so it holds for the rest of the day. I use cable and have had Comcast come out and check all connections and everything is tight. We put another TV next to mine using the coaxial cable and that TV worked fine? Is this TV repairable?
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Posted on Apr 10, 2009
My tv want come on at all but it was working fine this morning
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV
amazon.com/dp/B004ZL2O9U/?tag=80e1-20
Amazon.com, Inc.Amazon.com: Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV (2011 Model): Electronics. ... The Federal Trade Commission (FTC) wants you to know that the ... It is in fact much brighter than my 82" set which also has a 180 watt lamp. ... any lightcoming in; it will cause rather bothersome reflections off the TV screen.
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV ...
Dec 26, 2015 | Mitsubishi WD-92840 92-Inch 1080p 3D...
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
Sep 04, 2009 | RCA 32V550T 32" TV
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
How do you reset a locked out channel when the code is forgotten?
Try pressing simultaneously the QV and 9 on the remote to bypass the parental lock. Then press the MENU button and go into the menu to turn the lock off. At least this is how it works on several other old Mitsubishi televisions. I don't have anything on ***********'s model, but this is worth a try. I hope it works for you.
Nov 12, 2008 | Mitsubishi Televison & Video
No picture
Can you repeatedly get the picture to come back when you push on the back of the set? If so, yes, its sounds like a bad connection.
What happens when you use the tuner of the TV and with it connected to cable? Do you get a picture?
- Jim
Feb 19, 2008 | Hitachi 35CX45B 35" TV
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Flashing green light
I had the same problem with a WS 55813,2004 model.Paid 130.00 for local Mitsubishi authorized dealer that told me I needed a new DM module at an additional 505.00. Called Sears and they repaired the board for 146.00 by replacing four capasitors on the board. The tech said there is an exolaination on the web that explaines how to do this. He said this is a very common problem and carries 8 caps with him.He even had to do this to his own tv. The caps are worth 8.00 total.
Oct 11, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi CK-3513R - Horizintal white line
this ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Apr 12, 2007 | Mitsubishi CK-35308 35" TV
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
