Problem is with a direct vent gas fireplace. Pilot light will not stay on after following proper lighting procedures. I have changed the thermocouple and that did not solve the problem.
  • 28 more comments
  • silviop Oct 20, 2008
    Brand is INSTA-FLAME
    Model number is DV34
    brand is  INST-FLAME
    model number is DV 34
    I've already done all that as I've explained in my original question. Is changing the gas valve the next logical step?
  • Anonymous Mar 11, 2014
    How to replace
    Printer only prints blank pages. I have replaced 2 new black ink cartridges
    2005 sequoia sounds/feels like brake is on
    nokia 3110c sim card registration failed
    My laptop Facebook account has been compromised and someone unknown to me is posting unauthorized information without my knowlede
    where i found the list of contact on Nokia E63
    My front wheel is always hot and makes noise when I am driving
    remove side view mirror
    GOT THE MICROWAVE OPEN.. THE SPRINGS ARE OFF THE LATCHES. TWO OF THEM. THE SPRINGS ARE OK AND IT DOESN'T APPEAR THAT THERE IS ANYTHING BENT OR BROKEN.. JUST DON'T KNOW HOW TO MOUNT THE SPRINGS BACK PLACE.. CAN YOU HELP
    upgraded low beam on2005 e53 bmw to xenon can only get one bulb to work
    Hsm25gftg sa model number
    I have replaced the carrier bearing in the sprocket hub. The chain has about 6000 miles on it. I have inspected both the front and rear sprocket. Neither one is missing teeth. I recently changed the rear tire. I never noticed it until the tire was changed. I have made certain that the chain is properly tensioned and that it is aligned properly. This is my daily ride to and from work. Any help would be great. Thank you for your time.
    Replaced both catridges on MG 2120 printer, but ink smudges when copying
    vivitar vivicam X024 camara
    need to add credit card to account
    added a battery and watch can't be set by me because i don't know what the button do other than start stop light
    my kia sorento turns over but wnt start
    turn tv on and after about 15 mins, it shuts off and then every 15 or so after you turn back on
    uphill problem, no changing gears
    Find extension for outlet hose for zanussi jet stream 1200 (or longer hose)
    1994 honda civic DX fireing order
    2003 murcury mountaineer low oil pressure
    1997 ford e 150 oil needle keep going up but its not knocking
    how to replace distributor on 96 acura tl
    the 2 green lights are on and it is running but now a yellow light came on to, why?
  • Anonymous Mar 12, 2014
    Canon VB-C50iR software
    i cant open it plz solve this
    Genius:
  • 1,847 Answers
Make sure you trace the wire to the flame sensor back to the board and see that it is still connected.
Posted on Oct 20, 2008
    Genius:
  • 1,550 Answers
You need to provide brand and model number .
It will be mostly connection oriented problem .
post back the details .
  • SAM ANDERSON Oct 20, 2008
    • Turn of gas to line for a few minutes to clear the gas out.
    • Turn knob to pilot (so the notch allows you to push the button down.
    • Turn on the gas.
    • Push pilot button down (generally red)
    • Light pilot while holing button down. (It may take a couple of minutes for the gas to reach the pilot)
    • Continue holding the button down for up to a minute (so the thermo coupling heats up and then let go)
    • If the pilot stays lit your all set. move knob to start or on.
    • If the pilot does not stay lit try it again. (if it fails again when
      you let off the button the thermocouple is probably bad replace it.
    • If this does not work you might have a bad valve or a plugged line
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 | Dishwashers
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
36ECMII pilot light won't light
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
Jan 04, 2014 | Fmi Fireplaces SDVBPD Direct Vent Propane...
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Gas fireplace wont stay lit- it is a sealed unit so can taccess the pilot or gas holes in the logs. is it safe to remove glass panel?
Yes, removing the glass is safe, if you do it carefully, so as not to break it. Put it well out of your way, after removing it. In fact, removing it is the only way to access and service the Pilot Assembly and the Burners.
If the pilot won't stay lit, there are several things that can cause this on a Direct Vent Gas Fireplace:
  • The direct vent on the outside of the house is block or clogged.
  • Wind is blowing back through the direct vent, blowing out the pilot.
  • Low gas pressure
  • A dirty pilot.
  • The thermocouple and/or Thermopile (part of the pilot assembly) has failed.
If you can provide me with the make and model number of your gas fireplace, I may be able to furnish you with an Owners Manual, that will help you to continue to troubleshoot the problem.
Hope this helped you.
Apr 29, 2011 | Heating & Cooling
Montigo fireplace model M38DV-PFC Pilot light will not stay on, what is the problem?
the thermal coupler is bad . that is the tube with the brass line going to the gas valve. and sets at the pilot.
Nov 28, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
I recently bought a house w/ a Marco gas fireplace. There is no owners manual and the company has gone out of business. I have never used a gas fireplace, so I have no experience w/ this. It has a direct...
Hi the key turns the gas on there is a arrow saying on /off turn to on .
remove front panel should lift up then down look for large metal plate should have lighting instrutions on them?
if not you will see a gas valve 1 maybe 2 black knobs look for the one with off pilot on , look for small knob red or black this the spark igniton , okay turn first knob to pilot and press in and hold in depress spark knob keep doing this untill pilotlights there might be air in the line so this might take time , when the pilot lights HOLD BUTTON IN STILL for 30 secs then release turn knob to on pilot should stay on if not do again , if stays on turn up thermosat if fitted or turn power on at switch you will have to find that will be near fireplace the other black knob turn sthe flame up and down hope this helps
Feb 09, 2010 | Leisure HOMEPRIDE Electric Fireplace...
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
293 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
