Question about Maxtor OneTouch A01B080 80 GB Hard Drive
Computer not recognizing my Maxtor hard drive
I have had no problems with my Maxtor 80GB hard drive but suddenly my computer no longer recognizes the drive.
When I click on 'My computer' it takes a long time for the drive icons to appear. The Maxtor light is flashing. When the icons finally appear, the Maxtor drive icon does not.
When I turn off the Maxtor drive, there is no problem with 'My Computer'.
The Maxtor drive is recognized in the 'removable disk' icon at the bottom of the screen. When I click on it, I get the message that it can't be removed as it is being used by another program.
Any suggestions?
Andrew
    Novelist:
  • 102 Answers
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Posted on Apr 16, 2017
5 Suggested Answers
SOURCE: My maxtor 200GB drive is not recognized by my CPU anymore!
I have had 2 Maxtor 3200's for a couple of years, and this seemed to happen periodically. After enough fiddling around and plugging and unplugging I've always managed to get both my PC's to recognize them eventually.
I have now started doing the opposite of what is recommended, namely, powering up the drive and then making the USB connection. Now I make the USB connection and then plug in the drive. This has worked reliably for at least 10 times.
Posted on Nov 05, 2008
  • 29 Answers
SOURCE: I have a maxtor icon with a lock on it. I click on "unlock" and nothing works
Have you tried right clicking on the drive and going into properties. Click on security option and make sure that all the permissions for the drive are active with the exception of special permissions. Also look at the advanced security settings and make sure that you have full control permissions. Hope this helps.
Posted on Dec 10, 2008
romsky79
  • 822 Answers
SOURCE: MAC Computer won't recognize Maxtor External Hard Drive
that disk is not detected by windows due to power failure to your hard drive. check power of your drive.
Posted on May 20, 2009
  • 21 Answers
SOURCE: Maxtor 3200 was working fine. Suddenly my
If it fails to show up on another computer, it's dead. When you finish kicking yourself for failing to back it up, you can take it to a shop and ask them to pull the actual HDD out of the case and try to mount it with a different adapter. (This is more or less what ikkenom suggested, but your machine may not have the proper connectors.) If you're really lucky, they'll discover that the drive is readable, and they can transfer your files to a new HDD. You will then go home and BACK UP those files, right?
Posted on Nov 04, 2009
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My computer no longer recognizes the Maxtor one
Windows may be recognizing the drive but not assigning a drive letter for some reason. you may need to go to disk management2_bing.gif and look for the drive there.
to do so go to control panel/administrative tools/computer management
once computer management is up find disk management, inside you will find all the drives that are connected to your computer, you should find your drive, If you do not then the drive may be bad or you are having usb issues.
If the drive is there but does not have a drive letter assigned to it, this may be because another drive has taken the letter normally assigned to it, you will need to right click on it and say "assign drive letter"
Let me know if this helps.
Mar 17, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Maxtor 3100 80GB External Hardrive clicking/humming sound.
This could be an issue with the circuit board.I am facing a similar problem & shown it for repairing. And facing issue in sourcing the IC. Seagate is giving support for maxtor after it has taken over. Data recovery is possible only if the circuit is working.
Jan 10, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Orange light
What is your operating system? Have you tried to force install this hardware? I need to know this before I can begin to troubleshoot.
Ryan Frame
Creative Energy Associates Technical Center
Aug 23, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
My computer will not recognize my maxtor personal storage suddenly when it has always worked before.
My Maxtor 3100 did work with my XP widow machine at one time. But suddently my computer doesn't recognize the USB connection. How do I fix this?
Proopt
Nov 09, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor OneTouch A01B080 80 GB Hard Drive Logo
287 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
