Question about Kenmore 72982 Gas Dryer
CLOTHES NOT DRYING
PROBLEM MAY BE SENSOR. DRYER FLAME CUTS OFF AND WILL NOT COME BACK ON.
  • 62 Answers
Heat coils
Posted on Oct 20, 2008
I have an LG gas dryer only 7yrs old. Some loads are coming out still soaked after the cycle has finished. I've looked through the back of the unit and the flame is igniting. However, I have noticed that...
i am not a dryer expert,so i can only make these suggestions.
1.make sure the lint filter is very clean.
2.make sure the dryer is sitting level on the floor.(if it isn't sitting straight on the floor,the clothes may not be touching the sensors,causing the heat to turn on & off while drying.
3 do not overload the dryer with wet clothes.
4.pick the right heat setting for the amount & type of clothes.
Mar 30, 2015 | LG Dryers
I have replaced radiant flame sensor, high limit thermostar, cycling thermostat, coil kit, and blower wheel on maytag dryer ldg9206aae, and still it takes forever to dry and is not hot enough.
if the flame is lighting like it should and you changed out all those parts did you clean out the lint filter duct and clean out the vent line?try removing the vent line from the back of the dryer and run it,if the flame stays on longer and it heats you have a blocked vent line,if the air can't move and that's all a dryer does the clothes can't dry
Apr 10, 2013 | Dryers
I have a KitchenAid clothes dryer and the drying cycle will not cut off automatically, i have to stop the dryer manually. What is the problem?
you have a bad exhaust sensor on the unit, when the clothes are dry and the temperature raises hotter and hotter, the sensor realizes the clothes are dry and breaks the circuit, the sensor is located on the exhaust tube. the exhaust tube is what the hose attaches to to vent the air outside, take the exhaust tube off, then the back of your dryer and look to see where the tube is that vents from the dryer to the back where the attachment was, there should be a sensor there with two wires, you can test it for continuity but it will probably be stuck closed so you will get continuity no mater how hot it gets, just replace it with a new on... its probably 25 bucks
Jan 01, 2013 | Dryers
Whirlpool duet gas dryer
The question is are your clothes getting dry? The flame does not stay on constantly, but cycles on and off. Now if the clothes aren't drying properly, then the first thing to check is if you have good air flow coming out of the back of the machine and air flow completely outside where the vent exhaust to. If that is good then most likely your flame sensor has gone bad and needs to be replaced.
Aug 25, 2012 | Whirlpool GEW9250 Electric Dryer
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
Dryer doesn't dry (flame cuts out)
279834 is the part number for the 2 coils ( kit ) which mount on the burner . Only 2 screws hold the coil retainer . One coil is opening ( shorting ) after it gets warm . Replaceing both will solve the problem . Easily replaceable .
May 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer takes hours to dry one load of clothes. Cleaned all lint from it. It's warm, not hot. Flame is on.
you need to either dismantle the venting pipe ductwork inside the dryer and get inside the duct and loosen all dried on lint which is holding moisture in,otherwise the cycling switch for the flame is cutting out tooooo sooooon and your not drying the load properly per selected load setting
Mar 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
Whirlpool gas dryer no heat
One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
I'm back to drying clothes.
Oct 03, 2009 | Whirlpool LGR5636L Gas Dryer
Maytag Atlantis Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Kenmore 72982 Gas Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
