Question about RCA RS2653 Shelf System
My RCA 5 Disc Changer will not turn on.
My RCA first started off with the screen freezing and not being able to turn it on so I always had to unplug it and then turn it on. Then It just shut off and I can not turn it on anymore.
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
alfredo_krau
  • 62 Answers
SOURCE: my 5 disc rca changer is not reading the disc
Try to clean laser lens with CD cleaning disc. If it not helps, then Your lens must to be replaced.
Posted on Sep 06, 2009
SOURCE: i need a manual for my rca 5-disc changer. it is a
try this website http://www.retrevo.com/support/RCA-RS2625-manual/id/402dj683/t/2/
i havent tryed it myself but i bet it will work
Posted on Dec 11, 2010
snowghost1
  • 784 Answers
SOURCE: I have an RCA RS-1289
it is saying 'no disc' because the laser eye is either out of alignment ( do to a dropped/bumped unit ) or the reader chip on the board is at fault, or the eye is not getting power, or a combination of all.
take the unit down to your local stereo repair shop and they will most likely replace the drive and laser unit. this should only cost about 65 to 80 dollars depending on where you live and what the shops hourly rate is. make sure you ask them the cost before you have the work done because if it is to expensive to fix - you might just want to buy a new system ((( ??? ))).
c...
Posted on Feb 10, 2011
ripleymojica
  • 643 Answers
SOURCE: I have an RCA Bookshelf
That problem is usually due to worn or stretched belts. Try replacing the belts or use a rejuvination liquid.
Posted on May 09, 2011
My mp3 player is frozen and wont start up
Try this:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2200
If that doesn't work and it is under warranty, take it back and get a new one.
Jul 17, 2009 | RCA M4208 MP3 Player
I have the RCA Opal 4gb Mp3 Player and it freezes up.
when you plug in your rca opal mp3 into your computer go to my computer look for the removable disk exp: removable disk (E:)
Jun 15, 2009 | Audio Players & Recorders
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
finich seting up ...go through the setup menu. and pushing ok instead of clear. if it continue this indicate the main ac is being interupted.. do you unplug it at night? or just power it down.
Dec 15, 2007 | RCA HD52W58 52" TV
RCA TH1010 MP3 Player freezes at the start up screen
connect the unit to the rear usb ports if not try to format the memory.
The rear usb ports are 2.0 and the memory is the same kind
Nov 10, 2007 | RCA TH1010 MP3 Player
RCA RS2653 Shelf System Logo
322 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
