Panasonic Lumix DMC-LZ2 Digital Camera
Problem for Panasonic Lumix DMC-LZ2 Digital Camera
Camera will not turn on
By mike10 on Jul 03, 2006
the camera will not turn on or show any signs of life even when there are new batteries in it.
Same Problem
Jan 24, 2009
-   The camera will not turn on, it is 3 weeks old and has new batteries in it. It was working one morning and then stopped working, for no apparant reason. I have replaced the batteries and reset it. No luck. Any ideas?-   sarahgschwar
Jan 05, 2009
-   My daughter has had the kidizoom digital camera from Vtech for one year now. It will not turn on with new batteries. We've tried several different brands too. Anyone know if Vtech will do anything about this? What site?-   Apple Blosso
Nov 24, 2008
-   Camera will not turn on even with new batteries. Have only had it a few months. :-(-   Yaini
Nov 14, 2008
-   camera will not turn on even with new batteries-   Guest
Oct 11, 2008
-   The camera will not turn on even though Ihave tried two lots of new batteries.-   beermuppet
Best Solution
posted on May 22, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
Solution #2
posted on Feb 17, 2007
Very Helpful)
kelley1987
Rank: Apprentice
Rating: 100%, 2 votes
try taking the batteries out and cleaning the ends of them off with a cloth...then blow inside the camera where the batteries go. I did this with mine and the thing turned right back on !
Was this helpful?
Yes
No
Solution #3
posted on Jul 03, 2006
Somewhat Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1893 votes
This could be any of hundreds of different faults so I'll give you the ones you can check yourself.
One or more of your batteries are faulty.
The battery contacts are dirty.
The batteries are inserted wrongly.
You have a problem with the lens mechanism.
Shake camera and listen for anything rattling around. If metal it could short anything out.
Check your troubleshooting chart in your user's manual.
Google for "Panasonic Lumix LZ2 problems"
Is the power switch feeling as if it's actually switching.
Has the camera been dropped or given swimming lessons.
Check all your switches to make sure nothing is disabled.
Apart from these it's impossible to say what's wrong. A trip to a repair shop may be in order.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #4
posted on Feb 14, 2007
Not Rated)
JoeO700
Rank: Guru
Rating: 90%, 168 votes
Mike, this is an issue with the DC converter in the camera which converts the batteries voltage into several regulated supplies for use by the camera. Return the camera the Sony Laredo and let them know what it is doing, some of these repairs are being done under warranty concession if you raise your voice a bit. Good luck with this.
Joe Weibel
Custom Electronics
(customelectronics.org)
Was this helpful?
Yes
No
Solution #5
posted on Jan 04, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Often when something like this happens (as in my case)the camera was working fine, then it wasn't. Here's what I did.
It seemed as though my original battery (almost 4 years old) was the cause. I charged it, but the camera would not activate. I ordered a new battery and fully charged it. To my dismay still not working. So, I fooled around a bit. Holding the camera in front of you with 'KONICA' to your left. Now, open the lens cover from the right bottom, pressing just as bit as you open it. This is all it took for me. It came to life, I got the blue light and the lens deployed and the camera is working just fine. Who knows, maybe a 'widgit' inside was a tiny bit sticky..
Solution #6
posted on Mar 20, 2007
Somewhat Helpful)
juribe2
Rank: Apprentice
Rating: 0%, 0 votes
I got this camera new last week and have the same problem. The camera works ok with 50% charged batteries but when i installa new batteries, the camera just wont turn on. It looks like if new batteries put too much voltage. Any aditional suggestion?
Was this helpful?
Yes
No
Solution #7
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have same problem(not the batteries or memory stick or any of the above) I would get another camera.
Popular Solutions for Panasonic Lumix DMC-LZ2
Questions and Unsolved Problems for Panasonic Lumix DMC-LZ2
Do you recommend Panasonic Lumix DMC-LZ2 Digital Camera?
Answer
Answer
I've Got Lumix FZ28 camera.... when i shoot in wide angle mode it shows a black spot on left side of... (More)
Answer
display screen black.... will take photos however you can't view them (hence cant see what your... (More)
Answer
Shows error that my camera is stuck between modes.
14 Other Users Have The Same Problem - Continued
Comment by frehea1, posted on Jul 20, 2008
When switched on, the only activity is that the indicator lamp blinks alternatively, green and red.
Comment by cinjaz, posted on May 07, 2008
Camera will not turn on at all....changed batteries, recharged batteries and there is nothing.
Comment by Guest, posted on Feb 14, 2008
camera will not turn on after new battery/or newly charged battery is installed.
Comment by viamaria, posted on Feb 10, 2008
my camera will not come to life,even with new batteries installed.
Comment by Shari408, posted on Feb 06, 2008
I try to turn on my camera and the green light flashes quickly but won't turn on. I have cleaned the battery and am debating whether to get a new battery or just take camera to the reapir shop. Before it started doing this I would take a picture then the camera would just turn off until the point it is at now where it will not turn on at all,
Panasonic DMC-FX01
Comment by Guest, posted on Jan 06, 2008
will not turn on at all. started to become difficult to turn on then nothing. Put in recharged batterys and cleaned contacts, nothing.
will not turn on at all. Put in recharged batterys and cleaned contacts, nothing.
Comment by Paul1066, posted on Nov 17, 2007
I can view what is on my camera no problem. When I turn the dial to take pictures I goes dead. I use the rechargeable batteries which came with the camera. They are fully charged but still nothing. If I put them in the charger for 5 min. it will work. If I inset brand new batteries it will not work. Very frustrating.
Comment by manitoutom, posted on Nov 15, 2007
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Lumix DMC-LZ2...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
