Question about Kenmore 23822 Top Load Washer
WONT SPIN AT ALL
I NOTICED THE SPIN CYCLE WONT WORK AT ALL.
  • 1 more comment
  • vikinggodmn Oct 23, 2008
    Mine will sometimes spin sometimes not...water left in bottom...agitator works sometimes. Is there a clutch to replace?
  • sunocoblue20 Nov 05, 2008
    My washer will do everything fine until it gets to the spin cycle. It was not doing this till i made the mistake of opening the washer during the spin cycle. Now, it just makes a wierd noise when it is suppose to spin.
  • Anonymous Jan 18, 2009
    IT WASHES FINE BUT WONT SPIN AT ALL
Check the coupling between the motor and the transmission plastic inexpensive part that goes bad alot
Posted on Oct 20, 2008
  • 62 Answers
Is there water left in drum, and does it aggitate.
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Kenmore washer top load all cycles normal but when in the rinse/spin cycle notice it does not seem to spin fast enough to remove water from clothes and the are wetter then normal
There could be a number of reasons My best guess is that it will reduce the spin speed if it thinks it can't drain properly. Check that all the pipes/ filters etc are clear and that it can drain all the water out. Also it wont spin fast if the load is unbalanced. Does the spin speed change according to loading or is it low all the time? It may have a motor control problem, but that seems unlikely if it's working normally other than the spin.
Jan 13, 2011 | Washing Machines
Door not locking nor spin cycle not working
Hi.
Before proceeding to spin the timer does a check on the lid switch.
You should be able to fix the problem replacing the lid switch.
Regards.
Ginko.
Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wont spin
Yes you will find a belt under the bottom of the machine. Check out first that it did not just over balance and cut out while spinning if so you will need to hit the reset buttonand check out spin cycle. Hope this helps
May 25, 2010 | GE WDSR2080D Top Load Washer
My washing machine wont wash. It will fill with water and drain in spin cycle. Someone help me! Could it be the belt?
It sounds like your "Agitator" or "spinner" is not working. It is hard to say without more details.
Here's a tip anyways:
Get a small socket set, and pull out your washer. Either on the back or the front of the machine (usually the back), there will be 6 to 12 small nuts and bolts that can be removed to pull the cover from the washer.
Once you have the cover off, run the machine and watch it. You will notice where the problem is if you keep your eyes open for it. Try setting it to "spin" to see if it spins. If it does, then go through the cycles until you notice what your washer is not doing.
**Warning** Although washers are fairly easy to work on, there are moving parts and wires in there, so please be careful with your hands**
Nov 11, 2009 | Cars & Trucks
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Basket wont spin, still agitates and drains...
  1. Check the carbon brushes on the motor. they are probably worn and easily replaced..
Nov 27, 2007 | Washing Machines
Won't spin
Jessi, you need to call for factory service so you wont void the warranty. A couple of things could be going on here. The filter before the drain pump could be clogged with stuff preventing a high spin. Pressure switch wont allow a high spin if it detects water in the tub. The main control and motor control talk to each other and controls the spin. There could be a loose harness or poor connection at one of the boards. I would call for service, it won't cost you a cent...Catriver..post back.
Mar 15, 2007 | Frigidaire GLTF1670A Front Load Washer
Kenmore 23822 Top Load Washer Logo
57 people viewed this question
Sal De
fordexpert
Robert Rankin
