Question about Panasonic DVD-LS850
Input connector broken inside - Panasonic DVD-LS850
  • 98 Answers
Depending if it was a clean break (solder still intact and the traces have not been damaged this would be a easy solder repair but if the traces are damaged looks like more of a detailed repair
Posted on Oct 21, 2008
How to change a fuse on a korg Sp-250
There is no fuse inside SP250. If the unit can't power ON,there maybe damage to the adapter,adapter cord/connector,or broken fuse inside the adapter.
If adapter is in good condition, then the damage is inside SP250.
The possibilities are on regulator section.
Check all parts in this section (figure 1).
Also maybe there is a broken soldering joints at DC input socket.
change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-0.jpg change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-1.jpgchange-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-3.jpg
Jun 01, 2014 | Korg SP-250
Panasonic tx 28md3 scart on tv has poor connection problem.
It's hard to tell from your description, but there could be a problem with a contact in the SCART connector (broken or deformed or dirty), a breaking wire inside the connector assembly, or on the TV side, it could be what's called a "cold solder joint" where the solder joining the connector lead with the PCB has broken down and is not making a good connection any more. This often happens in a solder joint that absorbs mechanical force.
You need a service person or a friend who's good with a soldering iron to take apart both the connector housing (first) to see if there's a problem in there, and then the TV (second) to look at the solder joints on the SCART connector to see if any are looking dull, cracked, or broken with a visible space around the lead.
Mar 31, 2013 | Televison & Video
LDVD32 - no sound
Some settings have got changed. Please look through the settings and correct it. Check whether any of the connectors are broken and stuck inside the inputs.
Jul 28, 2012 | LG 32LG30 32 in. LCD HDTV
Gas guage shows over full all the time
You have lost the ground input to the gas gage. Its the black wire coming from the fuel pump connector at the fuel pump. Either the wire is broken or the input to the body control computer is broken, thus creating high Resistance on the input wire. The computer will think the tank is full, a shorted wire would indicate lo Resistance and read empty. Locate the fuel pump connector and jumper the black wire directly to the body (ground) and turn the key to run, check gage. If reads normal the wire is broken betwwen fuel tank and its ground location.
Jan 29, 2011 | 2000 Pontiac Firebird
VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Oct 25, 2010 | ViewSonic PJD5111 Projector
On able to use hdmi or usb inputs
HDMI and USB both run off the 5 volt power inside the TV. It is possible the 5 volt power is down in the set. Shop repair time.
HDMI connectors are frequently broken by allowing the wires to hang at the back of the TV. Most USB connections can only be used for MPEG movies and pictures. Check your owner's manual.
Mar 29, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Aug 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Cable input connector broken off
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Jul 25, 2009 | Televison & Video
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
Panasonic DVD-LS850 Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
