Question about Onkyo TX-DS494 Receiver
High pitch squeal when using optic input
I'm getting a high pitch (almost feedback type) noise when using the optic input selector. This has happened when connected to the DVD and cable box sources. It is worse when the receiver is cold and gradually goes away as the equipment warms up. This can take 30 to 60 minutes.
Is this a known problem with this equipment? Or is there a change to the connections that will eliminate the noise?
Thanks for your help.
  • 9 Answers
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Posted on Aug 14, 2007
DickCanFixIt
  • 948 Answers
SOURCE: Having problems with HDMI connection
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Posted on Jan 01, 2009
SOURCE: No video throught HDMI output
I have solved this problem. I've managed to get my Sky HD and Playstation 3 to play through the amp. You setup the HDMI inputs in the Input/Output assign. Once you have donew that go to the 'Source Setup' menu, select 'A/V Sync' then press enter as requested, you should then see an image. This worked with me after fiddling around with it for a while but it does work.
Posted on Feb 01, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
smarthome2
  • 1114 Answers
SOURCE: 1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
Posted on May 23, 2009
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 | Music
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
When driving or starting the car i notice when using the brakes it makes a squeaking noise - not all the time think its possibly damp causing it as it was raining yesterday and it happened but no rain...
To address your first problem squeaking brakes aka "brake squeal", is most often casued by one or 2 things: "Pad vibration" or a "low brake warning sensor".
Pad vibation is usually caused by ineffective pad anti-rattling clips & hardware that allow the pads to vibrate at a super fast speed whenever the brakes are applied, thus causing a high pitch brake squeal. To correct this, replace all the pad hardware and anti-rattling clips and make sure you use a quality pad set that has anti-rattling plates attached to the backs of them. Weather conditions do affect brake squeal, that is why it seems to be worse at times.
Low brake warning sensor squeal occurs when your brake pads reach the point of replacement, the sensor attached to the pads scrapes on the rotor which produces a high pitch squealing sound to warn you it's time for new pads.
As far as your second problem goes (a knocking sound), I'll need more information about the problem before I can offer a possible cause (eg. happens on left or right turns, while going over bumps, at high or low speeds, accellerating...).
Sep 22, 2011 | 2001 Ford Focus
I get a high pitched noise when in pro tools
I don't know what devices are connected to your audio input ports, sounds like gain is too high on a microphone or guitar or speaker setting too close to your work station, sound like feedback loop.
Nov 02, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
I have a 2005 duramax deciel pickup that has a high pitch squeal.
sounds like u may have a hole somewhere or maybe turbo aint getting enough oil does it sound like a turbine ?
Dec 23, 2009 | 1999 Chevrolet C2500
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
High pitched squealing noise when i start engine
have Your alternator belt checked for the propper tension:]
Jun 17, 2009 | 2003 Nissan Frontier Crew Cab
High-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
Mar 02, 2008 | Sony DAV-FC7 System
Optical sound problem
i have the same problem with the RZ-4900AV, it manifests itself when any video application runs through either the optical or coaxial input. in my case it's definitely not the optical cable itself, which works fine on another receiver. optical or coaxial input of audio CD's is fine, but a DVD video on the same DVD player gives the high pitched whine. the same with the PS2 on the optical input, audio CD in the PS2 no problem, PS2 game or DVD video gives the whine... i think, unfortunately, it's a crap receiver... and i solved the problem by buying a RZ-6900AV, which works perfectly in exactly the same environment.
Sep 10, 2007 | Sony Playstation 3 (PS3) Console
Onkyo TX-DS494 Receiver Logo
29 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
