Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Magnavox 27MDTR10S TV/VCR/DVD VCR Problem
When I try to FF or Rewind VCR tape with tape not playing it shuts TV down and ejects tape. I can FF and FR when tape is playing??? Any ideas? I have not opened it up and looked yet, thought I would ask first. I am a tech and have experience with TV's and such.
Thank you,
Mike Wassmuth
5 Suggested Answers
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
  • 28 Answers
SOURCE: VCR TAPE IS STICK IN VCR PLAYER.
if you can't get the tape out enough to pull it very carefully out by hand, you'll have to bring it to a repair shop. the tape is probably twisted up inside and jammed.
Posted on Nov 09, 2007
  • 173 Answers
SOURCE: Magnavox VCR/DVD recorder model ZV450mw8.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Posted on Feb 03, 2009
mybradley7
  • 242 Answers
SOURCE: VCR playback sound and picture don't match
use a cleaning tape. you lost me sorry
Posted on Jul 15, 2010
  • 36 Answers
SOURCE: VCR stuck in VCR eject mode
You can get the manual here. Maybe it will help:
http://www.retrevo.com/support/Philips-27MC4304%2F17-TVs-manual/id/277bh936/t/2/
Posted on Jul 25, 2010
Magnavox ZV450MW8 shuts off when trying to rewind.
Unplug the machine and pick it up and shake it, this will tell you if something is in there that shouldn't be or that something broke off.
So many things could be wrong that it is probably not worth fixing if it is not a foreign object inside.
May 15, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
Dec 03, 2012 | GoVideo VR4940 DVD Player/VCR
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Philips DVP3345V powers off after 10 seconds.....
If unit has auto rewind \eject feature? Try getting it into F Forward mode befoe it powers down....
Aug 26, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Feb 15, 2008 | Televison & Video
Symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
