Question about Miller TELEVIDEO 995 TERMINAL W/ GREEN SCREEN (TV995GREEN) Network Terminal
My TV turns a Green scren
I was watching tv and my screen turn on green, the audio is okey I can change the chanels. Some advice Can I repair or buy a New one Thanks
  • 4 more comments
  • Dannyboy_1 Nov 03, 2007
    I to Own a Panasonic 50" Plasma TV TH50PZ700 and every so often while watching TV my screen suddenly turns all green. I switch it off and turn it back on some times it is then ok for awhile.But then a few days later it does the same thing. I have sound but no picture. I I phoned Panasonic they said it was the cable company. I got them in and they changed my cable Box, but still it happens. Now the cable company is saying it is either Panasonic the TV or my HDMI cables. I hope someone out there can help me as I am confused and don't know who to blame for my troubles.
  • Anonymous Apr 13, 2008
    i have a vizio 50inch. and my screen is green also and i need help also.i turned it off 4 awhile but it remains green.what do i do?
  • rlnormanjr Sep 22, 2008
    The screen or is green with no Video cable connected. When cable is connected the picture is also green but u see images. Please help.
  • Anonymous Nov 03, 2008
    my screen is always green
  • redken Nov 18, 2008
    green screen,turn off an back on after a short while seem's to clear can you help
  • avtbanana Jan 22, 2009
    My son was watching tv last night and the screen just went green, it's a 32 in. Westinghouse house. I check it again the next day and it's still green. Does any one know how and if this can be fixed?
    Thanks,A
Hi have a samsung 50 inch plazma tv . But saddenly it turned out be green screen, i am realy mad becouse i bought it $3200 on july 2007. please give me any helppfull idea.
thanks biruk.
Posted on Mar 15, 2008
    Problem Solver:
  • 8 Answers
My Hitachi has similar problem with the green screens. It turned out I fed the output RF port with my second DirecTV output and cause the video board to "panic". To fix it, make sure all the video inputs are connecting to the right outputs of your cable, satellite, receivers, etc. Turn off power and unplug the cord for at least 3 minutes for the board to reset and plug back in. It shoud work for Hitachi but not sure what may cause the problem for other TV.
Posted on Jan 28, 2009
    President:
  • 2,022 Answers
Check your data cable
Posted on Sep 24, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
My sony kp-51ws500 tv screen would turn green and stay on for about 30 sec, then trun off. I adjusted the green screen button on the black box in the front of the tv....via info from this site. It fix the...
Doing the adjustment is not actually a fix, all that does is change the drive amount of the green CRT which allows the set to work but the 3 CRts will be out of balance so picture color will be affected. The only way to repair a bad CRT is to replace the CRT itself. You can get replacement Green CRT from www.tvrepairworld.com
Jul 30, 2011 | Sony KP-51WS500 51" Rear Projection...
The tv was working fine the other day. I turned it out today and the screen just stays black. If I press the channel button up or down the channels change and sound comes out. The audio works fine, but the...
Turn it off/on a few times within a few mins each times.U get a flashes of picture about 10 to 20 sec?Than ur LCD inverter board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It usally a long PC board in shape.
Apr 16, 2010 | Polaroid FLM-3232 Television
The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines and you can see the goast chanel behind the green lines. On pic in a pic setting the pic. chanel is...
Exact same thing happened to me last night. The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines. Light is definitely on and visible in the back. Now goes out after abut 30 sec. Misery loves company. Will watch the site for a solution. 4yrs. old just went off extended warranty 45 days ago. damn
Feb 12, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
Jan 09, 2009 | JVC HD-61G787 61" Television
Too much green
You may have had a power surge resulting in the screen being magnetised or else the colour amp may have failed. refer to your local tv repairer. Good Luck, Jus004
Jan 05, 2008 | GE 31GT740 31" TV
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Computers & Internet Logo
1,977 people viewed this question
Top Miller Computers & Internet Experts
Alun Cox
Are you a Miller Computer and Internet Expert? Answer questions, earn points and help others
