Question about SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB rarely turns on.
My girlfriends Sansa Clip 2GB only comes on when it wants to. It works perfect once it comes on but when it gets shut off it wont come back on for days sometimes. I opened it and the battery has 3.7v but it wont power up even when connected to the pc. She only had it for 2 months and took good care of it.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
http://forums.sandisk.com/sansa/
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip has seemed to just stop working, it wont come on. what could be the problem?
Respected Sir,
I lost sansa installation cd (2gb). Kindly requesting you to help regarding this matter
Nov 13, 2009 | SanDisk Sansa Clip MP3 Player
Bought Sansa 2GB mp3 player and can't work radio
Dude I have one in front of me so listen and follow along first turn the unit on, second push the menu button, this is the very small buttonright to the right of the SANSA namewhen you push that button the first thing you will see is the words MUSIC while thats on the screen hit the play button that looks like this >|| and you will scroll through all the settings you will see the fm radio selection when you get to it hit the middle button and the radio will come on.
Mar 21, 2009 | SanDisk Sansa Clip MP3 Player
My SanDisk Sansa Clip 2GB* MP3 Player shuts off after it plays one song. Is there any way I can get a instruction book I lost mine.
To obtain the manual for your device, please click on the link below or copy it and paste it to your browser...
http://www.sandisk.com/assets/file/downloads/user-guides/clip-usermanual.pdf
i hope that helps
Thank you
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Where can i find the driver for sansa clip mp3 2gb? where i can find the driver for sansa clip mp3 2gb
Go to sandisk.com. Click on downloads. Select sansa clip from the product list, then your operating system. You can get the updated driver and user manual.
Dec 10, 2008 | SanDisk Sansa Clip MP3 Player
My SanDisk Sansa Clip MP3 Player does turn on but does'nt work.
this should fix it, a tiny software that fixed mine just fine
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Nov 20, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player driver 2GB
The drivers and all software is available from Sandisk's website.
Oct 23, 2008 | SanDisk Sansa Clip MP3 Player
Player shuts itself off
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Aug 22, 2008 | SanDisk Sansa Clip MP3 Player
2gb clip help
-Tha Mp3 Doctor
Jul 15, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb
May 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
91 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
