Question about Whirlpool RBS275PD Electric Single Oven
Bottom element does not work during the cleaning cycle
The bottom element in my oven works during the bake cycle but does not turn on during the cleaning cyle. I have used the self clean 3 times before and both elements were on during the cleaning cycle. Now it wont clean because it obvioiusly doesn't get hot enough? Does it have anything to do with a fuse?
SOURCE:
huuum
  • 750 Answers
SOURCE: Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    • 1531 Answers
    SOURCE: My oven says that it's on (heating up or cleaning,
    no i do not think your elements are bad.it soundsd more like the main control board has malfunctioned.
    Posted on Sep 16, 2009
    Testimonial: "Thanks, I'll take a look."
    SOURCE: I recently put my oven through the self clean
    Probably the Thermal Overload Sensor burned out from the excessive heat during the cleaning cycle. It Is located on back side of oven.
    Posted on Oct 18, 2009
    SOURCE: I have a whirlpool single electric oven mod.
    I have the same problem. How did you check the element?
    Posted on Sep 15, 2010
    Bottom element doesnt work in oven, but top does.
    NOPE!
    1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
    2. Many ovens use both elements during bake cycle
    3. self clean cycle uses broil element
    4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
    5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
    6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
    7. Bake elements usually cost only $40-$60. No jury rigging required.
    Hope this helps ;)
    Mar 29, 2010 | Ovens
    Upper oven elements don't heat
    Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
    Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
    Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
    We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
    Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Bottom oven doesn't heat after running self-clean cycle
    Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
    GE JTP56 double oven controls OK top OK bottom no heat
    have you inserted the business card as described in the solutions?
    Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
    Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
    baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
    May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
    Self-clean not cleaning
    I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
    Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
    Amana Convection oven not controlling temp
    I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
    Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
    Whirlpool oven issue
    Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
    Whirlpool RBS275PD Electric Single Oven Logo
    47 people viewed this question
    Top Whirlpool Ovens Experts
    Craig Butler
    Craig Butler
    Steve Allison
    Steve Allison
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
