Home | Memorex | MVD2022 DVD Player | Memorex dvd player psc...
Memorex MVD2022 DVD Player
Problem for Memorex MVD2022 DVD Player
Memorex dvd player pscan split screen
By bigredgirl on Jul 03, 2006
I cant get my dvd to run without the pscan split screen coming help.... follwed directions in manual it didnt work HELP memorex dvd player model#mvd2022
Same Problem
May 20, 2009
-   I have the same problem, and i have had it before, i didn't use my dvd player for a while and it fixed it's self. Now i have the problem again, if anyone has a solution, please help. -   Guest
Apr 26, 2009
-   a pioneer dvd player has a split screen when opened -   Guest
Apr 06, 2009
-   split screen with pscan in center
-   Guest
Mar 30, 2009
-   i have the exact same thing it has a yellow box that says PSCAN and a black triangle with a yellow ! in it. i dont know what to do and it is making like clicking noises along with it sometimes skipping a part of the dvd-   allyi
Feb 28, 2009
-   the pscan thing keeps coming up and splitting the scree and we cant get it to work-   Guest
Best Solution
posted on Jan 05, 2007
Very Helpful)
neen
Rank: Apprentice
Rating: 100%, 37 votes
I just had the same problem and I looked in the back of my Memorex dvd player and there was actually a button where you can turn the progressive scan on or off.
Was this helpful?
Yes
No
30 people thought this was helpful
Solution #2
posted on Jul 31, 2006
Very Helpful)
Wizard_Yo
Rank: Apprentice
Rating: 100%, 91 votes
Memorex MVD2042 - The only switch on the back of the unit had gotten bumped when something fell behind the unit, thus causing the same issue mentioned here. Looking at the front of the unit, the switch is straight back from the disc tray on the left. (of course, if you're looking at the back, it's on the right side) This switch is for "Progressive Scan" either "on" or "off"
Thanks,
Wizard_Yo
Was this helpful?
Yes
No
75 people thought this was helpful
Solution #3
posted on Jan 27, 2007
Very Helpful)
spyder99
Rank: Apprentice
Rating: 99%, 223 votes
On the back of the dvd player there is a switch to cut the progressive scan on and off. it should be off and u should be set to go. i referred over to this and discovered it back there. Hopefully this should help you. Good Luck!:)
Was this helpful?
Yes
No
15 people thought this was helpful
Solution #4
posted on Jan 20, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks you i didnt relize i moved the switch on mvd 2042!
Solution #5
posted on Feb 28, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yES THE BOTTON TO CUT OFF THE PSCAN IS ON THE BACK. GOOD THING YOU GUYS POSTED THIS - I WAS READY TO THROW IT UP AGAINST THE WALL!! :-)
Solution #6
posted on Mar 08, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My OTIC DVD does not have a Pscan button on the back, and holding the Stop key for five seconds didn't work either, but pressing the V Mode button did work. Now it's perfect.
It was also playing in black and white, and hitting the PAL button fixed that. So, one happy camper here
Solution #7
posted on Apr 21, 2007
Very Helpful)
mbiletzki
Rank: Apprentice
Rating: 98%, 7 votes
If you have a jwin jd-vd502, click the I/P button on the bottom of the remote!
Comments:
Apr 21, 2007
- If you have a jwin jd-vd502 click the I/P button on the bottom left of the remote!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #8
posted on Sep 28, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
On your remote, there may be a button P-Scan, which you may have inadvertently pressed. So turn on the dvd, and press the button, it goes to normal mode.......just wonderful! I just realized this button was there........lol! Thanks everyone for trying to help.
Solution #9
posted on Jan 14, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Press on the stop button for 5 seconds.
It will take you out of the pscan.
Solution #10
posted on Dec 28, 2006
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The switch worked (that's what you get for cleaning).
Solution #11
posted on Jul 20, 2006
Helpful)
fairlane
Rank: Guru
Rating: 88%, 416 votes
Hi
I don't know if this will help, but it is one of the most common faults I see when a DVD player is brought in. The problem is that your DVD player is set for progressive scan output, and your tv is not capable of that input. I am not familiar with your model specifically, but there should be a F.A.Q. section in your manual and a procedure to to take it out of progressive scan mode. If that is what you found, and you followed the procedure, then there must be a glitch in the built-in program. If it is not a very old model, the place you purchased it, may be able to show you how to get it out of pscan mode, and probably not charge you.
Good Luck!
Was this helpful?
Yes
No
Solution #12
posted on Mar 01, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks the button on the back worked!!! I was trying to fix it off the menu for 2 hours.
Solution #13
posted on May 24, 2008
Very Helpful)
cootershome
Rank: Apprentice
Rating: 100%, 1 votes
THANK YOU THANK YOU almost had a melt down when i couldnt figure it out, but all better now, stupid little switch
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #14
posted on Feb 20, 2008
Very Helpful)
Elizbieta
Rank: Apprentice
Rating: 100%, 3 votes
Thanx. Called the Source and they didn't know but flipping progressive scan switch on back... perfect.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #15
posted on May 22, 2008
Somewhat Helpful)
salamandre
Rank: Apprentice
Rating: 75%, 1 votes
I tried all buttons and I got on a "reset" button, It works perfectly now.
Was this helpful?
Yes
No
Solution #16
posted on Jun 11, 2009
Not Rated)
bassit_89
Rank: Apprentice
Rating: 0%, 0 votes
thanx guys alot me and my dad were about to take it to the range and shoot it lolz XD
Was this helpful?
Yes
No
Solution #17
posted on Mar 25, 2009
Not Rated)
riptide811
Rank: Apprentice
Rating: 0%, 0 votes
For the Sanyo DVD dx-501 that we were trying to get to work, we pressed the V-Mode button twice and it worked!
Was this helpful?
Yes
No
Solution #18
posted on Nov 01, 2008
Not Rated)
langdon03
Rank: Apprentice
Rating: 0%, 0 votes
I no longer have the manual and the remote won't work either. What do I do?
Was this helpful?
Yes
No
Solution #19
posted on Sep 20, 2008
Not Rated)
cheshirekat3
Rank: Apprentice
Rating: 0%, 0 votes
Thank you! I knew that "PSCAN" triangle was trying to tell me something - BUT WHAT? Now I have a different problem - the setup button on the remote won't work. It worked a minute ago. Is this a low tech problem like - low batteries?
Was this helpful?
Yes
No
Solution #20
posted on Sep 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My remote had the I/P button which turned the progressive scan on/off. This worked. Although I am trying to figure out how it was turned on in the first place. My PSCAN Message showed up when I was trying to FFWD.
Solution #21
posted on Nov 07, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yes switching from progressive scan to reg mode did take off the pscan logo and split screen it the switch on the back of the unit.ps hopes this helps:)
Popular Solutions for Memorex MVD2022 DVD Player
Questions and Unsolved Problems for Memorex MVD2022 DVD Player
Do you recommend Memorex MVD2022 DVD Player?
Answer
Answer
How do I get rid of the PSCAN on my Memorex Progressive Scan DVD player??? I have a split screen... (More)
Answer
Big Easy One URC 5650 code for Memorex DVD Player
Answer
no video out but there is audio, cant see the video on tv but i can hear the audio, i've replace the... (More)
Answer
I have a sankey dvd player, and now the tray wouldn't open and on the screen it says tray error. can... (More)
Answer
pscan split screen on memorex dvd player help
61 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 16, 2009
all of the buttons are not HELPING.
Comment by Guest, posted on Dec 30, 2008
I also have the same problem
Comment by Guest, posted on Dec 25, 2008
a split screen.
Comment by Guest, posted on Dec 12, 2008
cant figure it out! i pressed every button! nothing worked!
Comment by tokeup, posted on Dec 06, 2008
split screen with a big orange sign in the middle of tv sayine PSCAN
Comment by Guest, posted on Nov 17, 2008
can't fix it!! help!
Comment by Guest, posted on Oct 24, 2008
Same problem. Don't know how to turn Pscan off.
Comment by Guest, posted on Oct 19, 2008
screen says pscan in a yellow box in the middle of the screen and the screen picture is split
Comment by nmfakoory, posted on Sep 28, 2008
I can't get the split screen to go away and there's a large PSCAN message in the center of the screen
Comment by Guest, posted on Sep 06, 2008
I HAVE THE SAME PSCAM SPLIT SCREEN AND CAN NOT GET RID OF IT
Comment by stagette, posted on Aug 31, 2008
I've read all on this issue (PSCAN). I havent got the remote for my dvd and there is no black switch on the back of the dvd player. any suggestions?
phillips 3020 dvd player
Comment by candi076, posted on Aug 28, 2008
Same problem split screen with PSCAN! in yellow triangle...Never even noticed the button in the back! Switched it, and PSCAN! immediately went away...And I have absolutely no clue how it got hit in the frst place...What in the world is it for anyway?
Comment by Guest, posted on Aug 23, 2008
Pressed buttons....we don't know what to do!!!!
Comment by samkakdi, posted on Aug 17, 2008
hi
i have a dimond v803-03 & its the same problem split screen with a pscan logo in a triangle...plz help...
thx
sam
Comment by ejpoor, posted on Aug 08, 2008
how do Iget rid of this? I'm not to got withvthese things.
Comment by Guest, posted on Jul 26, 2008
cant erase pscan
Comment by Guest, posted on Jul 23, 2008
stuck on pscan
Comment by Guest, posted on Jul 02, 2008
Thanks so much. I have a Memorex DVD player and switching the progressive scan off was the fix I needed.
Comment by aproblemhere, posted on Jun 18, 2008
same exact problem
Comment by Misol, posted on Jun 14, 2008
can't get the pscan split screen removed. please assist.
Comment by Guest, posted on Jun 10, 2008
the pscan thing comes up and it splits the screen what do i do to fix it
Comment by Guest, posted on Jun 09, 2008
yes. same problem
Comment by shannon30033, posted on Jun 08, 2008
Can't get Pscan off screen.
Comment by Guest, posted on Jun 07, 2008
P Scan split screen won't go away on my Aspire Digital DVD player! Got a universal remote and can't get it to make the P Scan go away. How do normalize the picture?
Comment by flash13, posted on May 28, 2008
Comment by Guest, posted on May 26, 2008
split screen
Comment by slbledsoe, posted on May 16, 2008
Comment by Guest, posted on May 11, 2008
I get the psan message and a split screen when I try to run my DVD player
Comment by Chuck1000, posted on May 03, 2008
That was quick!
Had same "p-scan" problem.
Saw your solution re: the "progressive scan" switch on back of unit.
Went and looked.
Switch was on.
Turned it to "off".
Works great!
Where do I send the $1,000,000,000?
Comment by MiaScull, posted on Apr 19, 2008
My dvd play has pscan on it and it has a split screen. What does it mean and how do I get rid of it?
Comment by Guest, posted on Apr 16, 2008
split sccreen
Comment by Guest, posted on Apr 12, 2008
I've tried everything.
Comment by Guest, posted on Mar 30, 2008
tried everything
Comment by Guest, posted on Mar 16, 2008
My manual is in spanish and I have a model #of MVD2042. And Ihave a split screen
Comment by vvelez, posted on Mar 09, 2008
my dvd is showing PS Scan and it's split in 2 . what should i do ?
Comment by Guest, posted on Mar 08, 2008
it splits the screen and has a yellow box satin pscan
I have a pscan message in the middle of the split screen. How do I remove this?
Comment by Guest, posted on Mar 04, 2008
Pscan comes up on my Memorex dvd player and it will not shut off! Help!
Comment by Guest, posted on Feb 24, 2008
Same problem.
Thanks for the same solution. Works great. What is the point of that switch? Memorex needs new engineers. I will never buy from Memorex again as it cost me needless hours and completely screwed up my new HDTV. Boo Memorex!!!!!
Comment by Guest, posted on Feb 23, 2008
Orange square with black triangle, and caps PSCAN in the center of screen, split screen with two pictures.
Comment by Guest, posted on Feb 21, 2008
I got the split screen with a Bright orange triangle in the middle of the scren that says: PSCAN!
Comment by Guest, posted on Feb 19, 2008
stuck on pscan
Comment by Guest, posted on Feb 07, 2008
ANNOYING
Comment by Guest, posted on Jan 20, 2008
i have the same problem i will try to switch it off & hope this works . thanks
Comment by rtlm, posted on Jan 14, 2008
had same pro blem o , but on differnt player.... I was going nuts trying to figure this one out. I can't find manual so i decided to look on line. I moved thing around in my home theater and must have hit the switch. so i'm now good to go ...... it worked !!!!!!!! thanks !!!!!
Comment by Guest, posted on Jan 08, 2008
split screen with psscan.
Comment by Guest, posted on Dec 25, 2007
I am now experiencing the same problem>>>>>
Comment by Guest, posted on Dec 23, 2007
i have the same problem with the memorex dvd player. been trying for weeks to fix and cannot. i don't have the manual anymore...so suggestions would be great!
Comment by Guest, posted on Dec 22, 2007
Another consumer said they had the same problem with the PSCAN that I had. There's a switch on the back of the player...I didn't even know it was there. My problem was solved. Thanks!
Comment by Guest, posted on Dec 16, 2007
how do I get the p! scan split off my dvd player for a gpx
Comment by gloria_m, posted on Dec 14, 2007
memorex dvd player pscan split
Comment by ctw4779, posted on Dec 10, 2007
Pscan with split screen!
Comment by Guest, posted on Dec 09, 2007
pscan split screen
Comment by red11282, posted on Dec 02, 2007
We have a split screen and it says PSCAN in the middle.
Comment by pmc001, posted on Nov 18, 2007
screen is split with yellow sign saying !PSCAN. How do I repair this?
Comment by Guest, posted on Nov 12, 2007
went thru weeks of frustration with split screen PSCAN...tonite was ready to buy new dvd player...thought i'd try internet...pscan switch on back was on...turned it off and no split-screen....YEAH !!!! thanx for letting me enjoy dvd's again with no extra expense.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Memorex MVD2022 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 683
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
