Question about Philips DVP642 DVD Player
Dvp642/37 power light, but no event screen
  • 88 Answers
Check the power unit inside of your DVDplayer .
if ok finaly check or replace MPEG PCB Inside of your DVDplayer .
Posted on Nov 14, 2008
Hybernate
Interesting, would expect it to be a setting in the Advanced Power Options but you've mentioned that you've disabled hibernation? If you go to Advanced Power Options and under the "Sleep" section, what have you got set for "Sleep After" and "Hibernate After"?
Also, do you have a screen saver set? It seems like its hibernating or sleeping after you have been idle or away from the PC for a certain amount of time.
You can try checking the event viewer around the time it happens to see if there are any corresponding events. Right-click Computer > Manage > Event Viewer, and check the system logs.
Jun 29, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Monitor goes off and on by itself
Hello bjaykaye,
The problems you are having are an indication of a Power Supply problem. The issue could be in the switching power supply or the High Voltage Power Supply. The shutdown circuit is activating which is allowing the TV to play until it detects an over-current event. When an over-current event happens the shutdown circuit will turn the TV off. I would suggest that you check the Horizontal Output Transistor, the HV Transformer, the Horizontal damper diode, and the capacitors that are in parallel to the damper diode. The important thing is to find the component that is causing the problem. If you do not have a background in electronics I would suggest that you get a qualified electronics technician to look at the set.
Thank you,
Shuttle83
Oct 29, 2007 | InFocus ScreenPlay 61" Rear Projection...
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Xps M1530 error code 2000-0322
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 09, 2012 | Dell XPS M1530 Laptop
Massive noise, now unable to access computer at all. constant amber light, not moving to next stage, nothing on screen, several thermal events previous to it blocking my access
Noise is most likely CPU Fan racing. Fault is most likely motherboard failure (Solid Amber power LED is usually MB and thermal events could be associated) Replace the motherboard
Feb 17, 2010 | Dell Optiplex GX280 (99301) Motherboard
Had a power surge at home and the screen the
Hi Geoff, You will need to open up your monitor. There will be a pcb fuse in the region of the mains input and you may need to replace some other components in that area which are designed to protect the monitor in just such an event as a power surge.
Nov 20, 2009 | LG 22" FLATRON LCD Monitor
Describe your RIM BlackBerry® Curve? 8330 Cellular Phone Problem Red light will not stop blinking
I own a Blackberry 8120. Have you tried a hard reset by pulling the battery and then restarting the phone? Also, events get caught in the phones memory process as well, causing reminder LED's to not clear after clearing the event. Go to options>security options>memory cleaning and enable the memory cleaning function. Set the icon setting to show on the home screen, memory cleaning is a function that many blackberry users under-utilize...the memory must be cleared just like a desktop PC, the rapid logging of events causes some to hang up. I believe one of these 2 solutions will help you out.
Jun 07, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Philips DVP642 DVD Player Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
