Emachines monitor has no signal
My E3516 emachines PC monitor has no signal. I found a solution on line to reload the BIOS, but I am a computer dummy and I am not sure how to follow these instructions. It says hit <delete> then <F5> then &F10> then <enter> Do I hit alt,delete, the ampersand and the letters g,t all at one time? Or alt,delete and the letters gt? Can someone help to guide me through?
  • Fran Bednar
    Fran Bednar May 11, 2010
    Where did you find this info ? Do you have a link ?
    You shouldn't have to mess with your bios to get a monitor to work ?
    Does the monitor start up and say NO SIGNAL ??
    New Friend:
  • 62 Answers
* First u can remove the display cable from cpu ( system ) .
1. Power LED coming or not .
2. Self cheak display or plain raster is comming or not. , both r ok ,
3. then u can cheak the display cable. & system.
4. 14 th pin is horizontel signal , 15 th is vertical signal , cheak the continuty the both wires.this signals is most importent for display.
Posted on Oct 21, 2008
Why am I not getting no signal between computer and monitor. Computer is emachine W3118
According to
eMachines W3118 8512780 eMachines Desktop PC User Guide
Your machine may support more than one monitor and have more than one monitor port. Change the cable connecting the computer and monitor to a different monitor port as the computer may not yet be configured for the port you have plugged the monitor in to.
Jul 06, 2014 | eMachines W3118 Motherboard Replacement...
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Emachines T3516 won't boot and displays "no signal" message
If you're using a VGA monitor, select to start up using VGA mode.
May 20, 2012 | E-Machines eMachines Desktop PC
No signal to moniter emachine t5048
DID YOU TRY A DIFFERENT MONITOR TO SEE IF THATS IT OR IT THE COMPUTER. SETTING COUSE THAT PROBLEM TO. THIS MAY HELP.
May 20, 2012 | eMachines T5048 PC Desktop
I am getting a no signal message on my monitor
Don't worry just reset of your bios default settings and check it now :)
May 14, 2010 | E-Machines eMachines Desktop PC
Onboard VGA port disabled, in Vista
You should try to disable it in the hardware list.
E-machines have an odd bios where not all the functions of the motherboard are available to the user.
If you can find the make and model of your board there is a good chance you can find the PROPER bios for it.
Emachines use motherboards from a variety of regular motherboard suppliers
My older e-machine has a hacked bios so that I can alter ALL the settings.
Aug 24, 2009 | eMachines EL1210-11 PC Desktop
Computer wont send signal to monitor
Make sure that the memory is completely seated in the slots. try re seating them.
If that does not do it, Find JP1, put the jumper so it is on both pins, then back on only one. this resets the bios.
Next time cleaning out the computer, just spray it out real good with a can of air, don't remove anything.
May 03, 2009 | E-Machines eMachines Desktop PC
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
Emachines computer problem
have you checked the cord and connection to the video card?also you could try resetting the bios.unplug the power cord on the pc.remove the batterie on the motherboard.power it back up.remove power cord again and replace batterie and restart pc.
Mar 04, 2009 | E-Machines eMachines Desktop PC
No signal to monitor
Try go to bios setup and then try resetting bios by selecting the bios default setting. and then look up for the configuration regarding your monitor setting or try to enabled that setting.
You can manipulate the bios setting ...don't forget to save the setting.
then try rebooting the system.
melnavz
Feb 11, 2009 | HP PAVILION A6230N DESKTOP PC
Computers & Internet Logo
622 people viewed this question
David Payne
David Payne
