Question about SanDisk Sansa e270 MP3 Player
Sansa e260 and e270
Question:
Does the Sansa e260 has only 2 volume settings :medium and high in the settings? is it the same with the Sansa270? With the Sansa 250 it has a control on the side that you can adjust the volume but I dont see one for the Sansa260. I want to purchase a Sansa270 but I dont know about the volume.
The scroll wheel on the front of the device controls the volume. clockwise for volume up, counterclockwise for volume down.
Posted on Nov 10, 2008
Volume to low need it to be louder
"Turn" the thumbwheel clockwise to increase the volume.
Oct 01, 2013 | SanDisk Sansa e260 MP3 Player
Ive a e260 v2 . which ive had since 2009. I was very pleased with the player Someone said the other week that i should Update the Firmware . So i did download the firmware search and it uploaded it,...
Hi, it might not be from the firmware update that the volume gets low.It might be from the speaker already getting bad without you noticing it. you can replace the speaker too it might work out.
Also firmware update can cause it too. Updating with the wrong firmware ...
You can use the below link to know the right firmware update to use for you san disk sansa e260 mp3 player..e200 might work with yours..
kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
1. Download the SANSA Updater from:
sandisk.com/sandisk-support/driver-download-wizard.aspx
2. Install Updater
3. Plug in the SANSA e260
4. If it needs new firmware, it will tell you to download and install.
5. Follow directions on screen.
Hope it helped.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e260 MP3 Player
For Sansa E260 MP3,can't get the volume up. Battery, headset fine
This link will show you how to take it apart. From there I suggest just try and clean it....Hope this works
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
Sansa E260 - I don't have USB Mode on my settings
Go look under Menu > Settings again. Either go UP two choices or down eleven choices and there it is.
Dec 23, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 volume
You can get an audio editor and turn up the levels - it would do us no good to tell you how to do this yet, since there are dozens of editors, and each program has a specific method - the manufacturers will tell you how to do this from their website.
Also, there is a "volume" menu setting on this player - make sure it is not turned down too low.
Jun 07, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e-260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 06, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
or
-Tha Mp3 Doctor
Nov 10, 2007 | SanDisk Sansa e260 MP3 Player
My mp3 does not play very loud through speakers
Did you check the settings in the info section? thee is a setting for volume there
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
E260 setting buton is no functioning Help
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
77 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
